5.7 temp gauge and EFI temp sensor #2678864
07/18/19 08:57 PM
07/18/19 08:57 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I think I have a small problem, I have my temp gauge electric sensor that I had on my old manifold from my 415, next to that in the other hole I had the EFI temp sensor. On the 5.7 I only have one npt hole. I need the temp sensor for the efi and I still want my gage to work.
any ideas?
Thank you
Kiddart
Re: 5.7 temp gauge and EFI temp sensor [Re: Kiddart] #2678866
07/18/19 09:10 PM
07/18/19 09:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I tapped 1/8"NPT threads near the thermostat housing for my electronic gauge. My ECU looks at the stock sensor.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 5.7 temp gauge and EFI temp sensor [Re: GoodysGotaCuda] #2678934
07/19/19 03:27 AM
07/19/19 03:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On the later years from around 2004 or somewhere around there Mopar started using just the one PCM coolant sensor for the PCM and the temp gauge. They actually started having the temp sensor hooked only to the PCM. Then the PCM uses it to know eng temp and it also sent that info over the buss to the instrument cluster so it could operate the temp gauge. Without the factory setup you will have to find or make a separate threaded hole for a stand alone temp gauge. Ron
Re: 5.7 temp gauge and EFI temp sensor [Re: Kiddart] #2678989
07/19/19 09:29 AM
07/19/19 09:29 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
On my daughters D100 we used the 04-08 car timing cover, the back of the block(the passages that go no where) had been tapped and the Heater hoses connected to them , That's where we put her mechanical gauge , installed at-fitting .
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 5.7 temp gauge and EFI temp sensor [Re: Ray408G3Hemi] #2678990
07/19/19 09:33 AM
07/19/19 09:33 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I think I am going to drill and tap a new hole opposite side of the factory location on the front top of block. its the triangle area just behind the front cover. on the drivers side there is a boss that I have the efi sensor in so I am going to drill and pipe tap just opposite of that. and hope for the best. should work just fine. cross my fingers. I will let you all know how it works out.
Thank you
Kiddart
Re: 5.7 temp gauge and EFI temp sensor [Re: Kiddart] #2679209
07/19/19 08:03 PM
07/19/19 08:03 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
All done, i figured i would screw this up somehow. But not this time
Thank you
Kiddart
Re: 5.7 temp gauge and EFI temp sensor [Re: Kiddart] #2679309
07/20/19 05:06 AM
07/20/19 05:06 AM
Springtown Pa
Springtown Pa
Looks good to me.
1996 Viper GTS
