Re: Bronze drive gear and bronze sleeve? [Re: BradH] #2677855
07/16/19 07:35 AM
07/16/19 07:35 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Originally Posted by BradH
Originally Posted by Stanton
Originally Posted by fuseable
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run.
Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!!
Bet it would cost me more than $10 to have someone machine my gear to use the $.25 washer, since I don't have the equipment to do it myself.
Maybe you need to make some friends !!! smile
Re: Bronze drive gear and bronze sleeve? [Re: Stanton] #2677915
07/16/19 11:23 AM
07/16/19 11:23 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I hear ya'. I lost my access to a Smithy when I moved my stuff out of a shared shop when my wife & I bought our house 20 years ago. Never thought I'd need to use it often enough to justify buying one for myself, and don't think that's really changed. It's only times like this where it would be handy to have it right there to knock out simple mods.
Re: Bronze drive gear and bronze sleeve? [Re: squirrel] #2678279
07/17/19 11:26 AM
07/17/19 11:26 AM
central il.
second 70 Offline
second 70  Offline
central il.
I checked this one that I changed out a few years ago and it has wear with a lip on bottom of gear but also the shaft is worn too.
Re: Bronze drive gear and bronze sleeve? [Re: Stanton] #2678283
07/17/19 11:41 AM
07/17/19 11:41 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Where do you get the 25 cent Torrington washer from? Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
1980 Plymouth Arrow 572 Hemi.
242" Mullis Dragster. 6.90@ 200mph
Re: Bronze drive gear and bronze sleeve? [Re: BANDIT] #2678286
07/17/19 11:48 AM
07/17/19 11:48 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Jim, I was wondering that also. I am also amazed that a Torrington roller thrust washer wouldn't brinnel a soft mating surface like brass. shruggy
Re: Bronze drive gear and bronze sleeve? [Re: 6PakBee] #2678339
07/17/19 02:15 PM
07/17/19 02:15 PM
AZ
squirrel Offline OP
squirrel  Offline OP
AZ
I think he meant the Torrington washer (the smooth race), not the Torrington thrust bearing (the thing with rollers). The washer is kind of thick for this application, facing the thrust surface of the gear in a lathe would be a good idea if you go that route?
Re: Bronze drive gear and bronze sleeve? [Re: squirrel] #2678619
07/18/19 10:28 AM
07/18/19 10:28 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I have a Smithy, so the machining isn’t a problem, was just wondering where to get washer. McMaster-Carr I guess is good as place as any to start. My Indy block actually had too much distance between bushing face and distributor mount surface, I took a little off of the bottom of the distributor to keep gear from moving so much. Jim
Re: Bronze drive gear and bronze sleeve? [Re: squirrel] #2678756
07/18/19 04:02 PM
07/18/19 04:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Exactly. The washer is .030 thick and smooth enough to run a bearing on so is sure as hell won't harm either the gear or the bushing. I buy them at local bearing supply shops - an "off the shelf" item.
Re: Bronze drive gear and bronze sleeve? [Re: second 70] #2678758
07/18/19 04:03 PM
07/18/19 04:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The lip and shaft are the least of your worries ... look at the wear on the gear !!!!
Re: Bronze drive gear and bronze sleeve? [Re: Stanton] #2678761
07/18/19 04:08 PM
07/18/19 04:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
Do you have a brand and part number for those good washers? help
Re: Bronze drive gear and bronze sleeve? [Re: Stanton] #2678762
07/18/19 04:10 PM
07/18/19 04:10 PM
iagree That gear is worn out scope
Re: Bronze drive gear and bronze sleeve? [Re: Cab_Burge] #2679067
07/19/19 11:09 AM
07/19/19 11:09 AM
central il.
second 70 Offline
second 70  Offline
central il.
I totally agree.This was my first time using one and was surprised how fast it wore out. It only had 3,000 street miles on it. I added a collar now and check it much more often.
Re: Bronze drive gear and bronze sleeve? [Re: second 70] #2679071
07/19/19 11:15 AM
07/19/19 11:15 AM
BradH Offline
BradH  Offline
Has restricting the gear movement w/ the collar showed reduction in wear?
Re: Bronze drive gear and bronze sleeve? [Re: BradH] #2679078
07/19/19 11:33 AM
07/19/19 11:33 AM
central il.
second 70 Offline
second 70  Offline
central il.
Sorry Brad I haven't put enough miles on it yet to find out.
Mike
Re: Bronze drive gear and bronze sleeve? [Re: second 70] #2679337
07/20/19 08:21 AM
07/20/19 08:21 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I replaced the gear and bushing last week.They were in there for 7 years,,over 50k miles and were plain wore out! Todd has them in stock. No spacers or bearings and the bushing has the oil grooves. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Bronze drive gear and bronze sleeve? [Re: hemi-itis] #2680870
07/24/19 09:59 AM
07/24/19 09:59 AM
central il.
second 70 Offline
second 70  Offline
central il.
Al can the new bushing be installed with engine in car and cam still installed?
Re: Bronze drive gear and bronze sleeve? [Re: second 70] #2681026
07/24/19 07:32 PM
07/24/19 07:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Absolutely.
Re: Bronze drive gear and bronze sleeve? [Re: Stanton] #2681139
07/25/19 07:56 AM
07/25/19 07:56 AM
BradH Offline
BradH  Offline
Absolutely.
There should be a thread from the last 4 to 6 months that talked about what tools can be used to remove & install the tower bushing.
