Is Dex/Merc fluid correct for 727 #2678341
07/17/19 03:22 PM
07/17/19 03:22 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
My 1970 727 trans is stock with stock torque convertor.
I saw Dex/Merc fluid that looks like it meets dexron II specs.
They also had a multi-vehicle fluid that looks like it would work also.
The other two fluids they had were ATF+4 and Type F. I really don't want a synthetic fluid.
I've searched the internet and it tends to get pretty involved.
So, is Dex/Merc correct to replace Dexron II??
Boy how times have changed. It used to be two fluids, Ford, and then everything else.
Re: Is Dex/Merc fluid correct for 727 [Re: SlickRS23] #2678607
07/18/19 11:06 AM
07/18/19 11:06 AM
moparx Offline
moparx  Offline
use type F, even the cheap stuff.
beer
Re: Is Dex/Merc fluid correct for 727 [Re: moparx] #2678667
07/18/19 01:01 PM
07/18/19 01:01 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Either F or Dex/Merc will work, I've run both in different 727s & 904s with no problems.
