70 Pymouth Body ID ? #2678382
07/17/19 05:54 PM
07/17/19 05:54 PM
usa
Mopar1970440 Offline OP
usa
Car in question is a Plymouth Satellite/Roadrunner shell, the car was used for parts...all bolt on sheet metal is gone and interior. Dash is gone, along with VIN plate, Data plate missing, and there is no title for the shell. It has the Big drum brakes and an 8 3/4 under it. Is there anywhere on the car to find a vin or partial VIN to tell what it was? I sanded down a part on the radiator support and I cant make the numbers out..but it looks like a date stamping almost? Thanks
Re: 70 Pymouth Body ID ? [Re: Mopar1970440] #2678384
07/17/19 05:59 PM
07/17/19 05:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you apply for a state issued VIN, as part of the inspection process they will use the body numbers to determine the full original VIN.
Those records are kept in a Federal database, so it is not just a call up & ask situation. The query has to come from a state agency, in this case it would be part of the state issued VIN application process.
Re: 70 Pymouth Body ID ? [Re: Alaskan_TA] #2678606
07/18/19 11:06 AM
07/18/19 11:06 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
VIN should be on rad support, on the cowl, and under the rubber seal on trunk side(s) . . .
Re: 70 Pymouth Body ID ? [Re: a12rag] #2678611
07/18/19 11:14 AM
07/18/19 11:14 AM
usa
usa
I can only make out a few numbers on the radiator support and it looks like there are dashes too so I was leaning toward that just being a date..? where on the cowl should I be looking?
ill check into under the seal on the trunk
Re: 70 Pymouth Body ID ? [Re: Mopar1970440] #2678642
07/18/19 12:11 PM
07/18/19 12:11 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I believe it was also on a body panel, in the area behind the rear license plate.
Re: 70 Pymouth Body ID ? [Re: Mopar1970440] #2678662
07/18/19 12:55 PM
07/18/19 12:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Driver's side rear quarter, under the weatherstrip. You are only going to get "BO123456" or not a "B" depending on where the car was made. We had the SAME scenario a few times back in the 80's at wrecking yards - one was a Moulin Rouge '70 GTX in TX, the other mystery car was a butterscotch 71 Cuda in CA. Never knew what either car had for drivetrain.
Re: 70 Pymouth Body ID ? [Re: Fab64] #2678664
07/18/19 12:57 PM
07/18/19 12:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The 11" drum brakes and 8.75 rearend are not a lock for it being a Road Runner; I had an original '70 Satellite wagon that had them.
That car was ordered like a wagon version of a 383 RR .
You might look at the quarter panels aft of the scoop area: Road Runner would have 4 holes on each panel for its name plates.
It would also have brackets for dual mufflers, though that's no guarantee it's a RR.
The partial VIN under the trunk weatherstrip will be towards the rear of the left quarter panel, but what you need to find is a full VIN stamp starting with RM.
Re: 70 Pymouth Body ID ? [Re: a12rag] #2678714
07/18/19 02:44 PM
07/18/19 02:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No cowl VIN on B-bodies before the 1971 model year.
