Project Egress #2678336
07/17/19 02:59 PM
07/17/19 02:59 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Have any of you guys looked into Project Egress with Adam Savage and the Smithsonian?
The Smithsonian gathered all the drawings to the parts that make up the hatch on the Apollo capsule. One man rendered all the drawings in Fusion360 CAD software. Adam Savage blew all of the drawings out to 44 different makers and asked them to build the parts out of the materials of their choosing. He has collected the parts and will be assembling the hatch on July 18th at the Smithsonian.
It's been fun watching the builds on YouTube. I follow some of the makers and have spent time with four of them (Blondihacks, OxToolCo, NYC CNC, and Jimmy Diresta). It's awesome that their work will be on display at the Smithsonian.
Adam Savage will document the assembly and no doubt the other makers will too.
https://www.tested.com/science/spac...s-project-national-air-and-space-museum/
Re: Project Egress [Re: feets] #2678396
07/17/19 06:33 PM
07/17/19 06:33 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Wasn't aware of it but sounds interesting.
That mechanism is fascinating; I assume that's the redesign after the Apollo 1 tragedy?
Re: Project Egress [Re: topside] #2678497
07/17/19 11:42 PM
07/17/19 11:42 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yes, it is the amazingly complex new hatch.
That thing is a pretty impressive piece.
Re: Project Egress [Re: feets] #2678555
07/18/19 08:24 AM
07/18/19 08:24 AM
nowhere
Sniper Online content
We know who you are
Sniper  Online Content
We know who you are
nowhere
no wonder space stuff costs so much
Not like no one else already had a tested and well proven quick acting hatch design in use in thousands of applications that couldn't have been easily adapted to work on Apollo.
Re: Project Egress [Re: Sniper] #2678577
07/18/19 09:37 AM
07/18/19 09:37 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Well, I don't pretend to be smarter than the Apollo engineers. But I'm thinking a submarine hatch would be colossally heavy and use completely different materials than something that would be flown into space. When you are dealing with space travel every gram counts.
Re: Project Egress [Re: wingman] #2678587
07/18/19 10:13 AM
07/18/19 10:13 AM
Middlesex County, New Jersey
DirectSubjection Online penguin-006
Tacohead. The First and Only
DirectSubjection  Online Penguin-006
And vacuum sealing is different I am sure too.
Re: Project Egress [Re: DirectSubjection] #2678596
07/18/19 10:44 AM
07/18/19 10:44 AM
Fragged State of Skuldruggery
srt Offline
srt  Offline
An elderly friend worked on the Apollo design and construction. He was an Thermodynamic Engineer and his expertise was thermal protection of the capsule. I asked him once about what was involved and he replied "do you want the short or long version", I opted for the short, 2 hours later..
It was amazing the amount of drive and desire to succeed these guys possess.
Re: Project Egress [Re: wingman] #2678700
07/18/19 02:19 PM
07/18/19 02:19 PM
nowhere
We know who you are
We know who you are
nowhere
Pretty sure I said there was a proven design that could be adapted not used as is.
It also has to be airtight, not vacuum tight. You want to keep the air in and forces working to let it out are opposite than if you were trying to maintain a vacuum instead. You want to place the door so that the pressure helps seal it.
Re: Project Egress [Re: srt] #2678729
07/18/19 03:39 PM
07/18/19 03:39 PM
RoadRunnerLuva Offline
It was amazing..BUT it was a totally different era in this country. It was a time where people still desired to work together for a great common goal, mandated by a forward
thinking, and inspirational President, who btw, never got to see NASA's fruits of their labor 50 years ago, this coming Saturday.
"Get busy living or get busy dying"....
1972 Plymouth Duster...418ci Stroker Small Block
1973 Dodge Charger SE Brougham...400 Magnum Big Block (SOLD)
1971 Plymouth Duster...360 4bbl (SOLD)
1970 Dodge Challenger...340 4bbl (SOLD)
1969 Dodge Dart...440 Big Block (SOLD) Burn't up in a fire
1969 Chrysler 300 Convertible...440 Big Block (SOLD)
1968 Dodge Dart Custom...318 4bbl (SOLD) Smashed/wrecked
1998 Dodge Dakota R/T 5.9 Magnum
2002 Jeep Grand Cherokee 4.0
Re: Project Egress [Re: RoadRunnerLuva] #2678892
07/18/19 10:12 PM
07/18/19 10:12 PM
Its a 2- piece unit redesigned from a 3 piece used during the fatal Apollo 1 fire. New regulations for the design were put in place - it had to open in 3 seconds and all 3 fully suited astronauts to exit in 30 seconds max. secondary requirements: 1 hand operation from either side, push opan and pull close from the inside, a pressure dump valve, a backup latching system, max 20 pounds of force to operate it.
Its rocket science after all biggrin
Here's the original technical memorandum of the design proceedings in case anyone is curious
http://www.ninfinger.org/models/vault2012/Apollo%20CM%20Hatch%20Design.pdf
Re: Project Egress [Re: DirectSubjection] #2678893
07/18/19 10:13 PM
07/18/19 10:13 PM
Re: Project Egress [Re: feets] #2679248
07/19/19 10:07 PM
07/19/19 10:07 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I like the concept. It's too bad Adam Savage is a total [censored].
2nd generation Charger rotisserie set-up
by hemi68charger. 08/18/19 09:02 PM
9-1/4" Axle - Auburn/Dana/Yukon Limited Slip?
by GoodysGotaCuda. 08/18/19 08:55 PM
If it had a kitchenette, I'd be moving....
by Satilite73. 08/18/19 08:28 PM
Trendz (Rick) helps my dinosaur racecar get a jolt!
by gregsdart. 08/18/19 08:10 PM
Moparts Recent Posts
by Satilite73. 08/18/19 09:16 PM
Waiting and WAITING for NHRA on FS1 !
by Doc Fiberglass. 08/18/19 09:06 PM
