2002 Durango 4x4 Torque Specs #2676512
07/11/19 09:01 AM
07/11/19 09:01 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
In the process of installing upper and lower ball joints on my 2002 Durango 4x4. I searched google but cannot come up with definitive torque specs for upper ball joint mounting nuts and bolts (3). Upper ball joint castle nut, Lower ball joint castle nut, outer tie rod nut and the spindle nut. Hoping someone here could help me out. Thanks in advance.
Re: 2002 Durango 4x4 Torque Specs [Re: cl440] #2678122
07/16/19 11:02 PM
07/16/19 11:02 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
AS per dealerconnect ;Install the ball joint into the steering knuckle and tighten the ball joint nut to 183 N·m (135 ft. lbs.)
Install the upper ball joint nut. Tighten to 81 N·m (60 ft. lbs.).
