6.1 stroker, head choices #2677807
07/15/19 10:43 PM
07/15/19 10:43 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I picked up a blown 6.1 engine to build an engine for my jeep, it has 2 spun rod bearings, so I will most likely do a 392 stroker. Topping it will be a whipple supercharger.I have to decide what to do with the heads. Go for a cnc port and rebuild the 6.1 heads, edelbrocks, or something else?
Anyone making dedicated blower cams for the gen3?
Re: 6.1 stroker, head choices [Re: Uberpube] #2677813
07/15/19 11:37 PM
07/15/19 11:37 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
You don’t need much cylinder head for a boosted motor unless the boost is high.
I’d do a stage 2 port from a guy like sixpackgut.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 6.1 stroker, head choices [Re: Uberpube] #2677991
07/16/19 05:01 PM
07/16/19 05:01 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Boosted Cams, MMX has a good one designed for 390+CI boosted engine,Call them an tell them What your looking for their custom cams won't break the bank
RLD has a Great 370-400Ci boosted cam ,part # RLD H2 3 weeks ago I was at my engine builders place he had a stock bore and stroke 6.1 with Hellcat heads and A 2.9 Whipple on it motor pulled 960@ 6800 with that cam.
HHP is another one to talk to about boosted G3s
Inertia Motorsports
OST Dyno , they are more into the Later G3hemi(VVT)
I'd Sell the 6.1 heads and get a set of the BGE heads(6.4 Truck) they are a stronger head less prone to cracking at higher boost pressures.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 6.1 stroker, head choices [Re: Uberpube] #2678154
07/17/19 02:54 AM
07/17/19 02:54 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of HP are you looking for? Plenty of forced induction forged 6.1's making massive power with stockish heads. 6.1's flow over 300cfm stock, I'd say do a good rebuild on them, maybe touch them up and spend your money elsewhere
Re: 6.1 stroker, head choices [Re: WO23Coronet] #2678182
07/17/19 08:15 AM
07/17/19 08:15 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I'd like to have 700 at the wheel.
Re: 6.1 stroker, head choices [Re: Uberpube] #2678347
07/17/19 03:33 PM
07/17/19 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you wan the best without breaking the bank get the BGE heads, but really any of them will do that easily, even the early 5.7 ones but I would get at least an eagle.
