71-74 B Body drip rail / roof rail weatherstrip channel #2677527
07/15/19 09:35 AM
07/15/19 09:35 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
E bodies have a stainless gutter / drip rail that screws to the roof. Thne there is a separate glavanized channel that holds the weatherstrip that gets screwed to the roof.
Are 71-74 B bodies the same? Do they have that separate stainless gutter that gets screwed to the roof?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 71-74 B Body drip rail / roof rail weatherstrip channel [Re: 71TA] #2677783
07/15/19 08:45 PM
07/15/19 08:45 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
My 74 Charger showing stainless driprail, weatherstrip and channel on drivers side rear of window opening during disassembly. I hope this is what you wanted to see.
Terry
Re: 71-74 B Body drip rail / roof rail weatherstrip channel [Re: 71vert340] #2677882
07/16/19 10:26 AM
07/16/19 10:26 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
The stainless does not screw to the drip edge/roof it is a friction fit over the drip edge of the roof.
Re: 71-74 B Body drip rail / roof rail weatherstrip channel [Re: 340cpe] #2677951
07/16/19 02:44 PM
07/16/19 02:44 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Yes, 340 cpe is correct. As soon as I removed my vinyl top and slipped the drip rail over as seen in my photo, it was loose. Only the channel screws into the roof. Since I'm not sure I'll be installing the vinyl top back on, I'll need to add something to keep drip rail tight.
Re: 71-74 B Body drip rail / roof rail weatherstrip channel [Re: 71vert340] #2678608
07/18/19 11:10 AM
07/18/19 11:10 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Great info guys! Thanks
E bodies have a separate stainless "drip rail" that screws to the roof. THEN the galvanized weatherstrip channel. So there is 2 layers of sealing strips required.
71-74 B bodies are obviously different.
Thank you. Thank you. The pictures are definitely worth a thousand words.
