Lift Collapse - 71 Hemi Cuda #2677494
07/15/19 07:36 AM
07/15/19 07:36 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Anyone know anything about this unfortunate incident? No details about who and when on the other board. I wonder if it’s recent?
https://www.garagejournal.com/forum/showthread.php?t=426085&showall=1
Re: Lift Collapse - 71 Hemi Cuda [Re: floyd] #2677497
07/15/19 08:10 AM
07/15/19 08:10 AM
P
Porter67 Offline
Porter67  Offline
P
Ive not seen it, thats terrible to look at.
Re: Lift Collapse - 71 Hemi Cuda [Re: Porter67] #2677508
07/15/19 08:46 AM
07/15/19 08:46 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
coulda been much worse...if someone was under it, or another car.
1969 Plymouth road runner post 383 4 speed F8
1981 Dodge D150 360 auto
Re: Lift Collapse - 71 Hemi Cuda [Re: basketcase] #2677530
07/15/19 09:37 AM
07/15/19 09:37 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I wonder what caused that?
Re: Lift Collapse - 71 Hemi Cuda [Re: ScottSmith_Harms] #2677537
07/15/19 09:48 AM
07/15/19 09:48 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Ouch. Looks to me like the posts weren't bolted down.
Re: Lift Collapse - 71 Hemi Cuda [Re: topside] #2677545
07/15/19 09:57 AM
07/15/19 09:57 AM
moparx Offline
moparx  Offline
wonder what brand that was ?
it is hard to look at. hope the guy had insurance. [but i'm sure he did]
beer
Re: Lift Collapse - 71 Hemi Cuda [Re: topside] #2677549
07/15/19 10:10 AM
07/15/19 10:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sure looks that way...........
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
HEMICUDA1 says I'm a leader
Re: Lift Collapse - 71 Hemi Cuda [Re: hemi-itis] #2677553
07/15/19 10:20 AM
07/15/19 10:20 AM
fullmetaljacket Offline
Looks like they weren't bolted down and or poor grade hardware material (Bolts) and or poor grade porous metals/craftsmanship and or poor leveling of the whole unit.
The luck in the draw is that no one was under it to end up being buried in a drawer.
That car now has to be gone over entirely to check its trueness drivability.
Take second looks first time fellas.
Re: Lift Collapse - 71 Hemi Cuda [Re: fullmetaljacket] #2677560
07/15/19 10:40 AM
07/15/19 10:40 AM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
I have a similar lift and it states they do not need to be bolted down but after the first time I lifted a car with it unbolted it was the last time... No thanks as I could easily see the load stresses shifting from vertical to horizontal quickly!! I am really surprised we have not seen more issues like this.
Re: Lift Collapse - 71 Hemi Cuda [Re: mymcodebee] #2677587
07/15/19 12:05 PM
07/15/19 12:05 PM
The problem with those types of instructions and or suggestions is that it originates in other places of manufacturing where the notion of Murphy is not thought of.
If it can happen, it most probably will at some time.
How would anyone lift a car on such a device without thinking that the slightest pull/tug (let me check the oil filter tightness or loosen that stubborn bolt) could trigger the weight displacement/distribution in the wrong direction.
It could have also been that the hydraulics/fluids slowly gave way and it was a gentle decent from what I am seeing. I would check everyone of those devices like NOW!
Anything that heavy floating above the waist belt is bound to tumble by a gust of a butterflies wings. Like I said guys, take second looks first time.
Re: Lift Collapse - 71 Hemi Cuda [Re: fullmetaljacket] #2677616
07/15/19 12:44 PM
07/15/19 12:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I sure doesn't look like the thing was bolted down. No chunks of concrete pulled up, no evidence of holes where broken hardware may have been.
I almost wonder if someone wasn't in the car, running the engine, bumped it in gear, then hit the brakes when the car started moving and the momentum parallelogramed the lift.
Re: Lift Collapse - 71 Hemi Cuda [Re: floyd] #2677629
07/15/19 01:04 PM
07/15/19 01:04 PM
central il.
second 70 Offline
second 70  Offline
central il.
Is it just me or do the bolts where the front left post should have been attached look intact? Surely they should have been bent or broken if it collapsed? Somebody forget to bolt it on?
Re: Lift Collapse - 71 Hemi Cuda [Re: second 70] #2677642
07/15/19 01:26 PM
07/15/19 01:26 PM
Also could have been no nuts put on the bolts as stated above. Thing is, those things also have lock downs on the way down. My friend had a few of those lifts and I remember the hydraulic fluid being a problem going up and down on one of them.
Lucked out that the car did not roll into the others on the very front or tipping and collapsing over and knocking the 440 model like dominos.
Re: Lift Collapse - 71 Hemi Cuda [Re: fullmetaljacket] #2677658
07/15/19 01:55 PM
07/15/19 01:55 PM
South Dakota
hotairballoonpilot Offline
South Dakota
mopar pondarossa maybe?
Contact Me about AMD Prices
Re: Lift Collapse - 71 Hemi Cuda [Re: hotairballoonpilot] #2677718
07/15/19 05:34 PM
07/15/19 05:34 PM
California
BloFish Offline
BloFish  Offline
California
Cringe frowwn
It doesn't really matter whether you win or loose...
as long as you look good doing it!
‘65 A100
‘69 Barracuda
‘06 Mega Cab 2500
‘14 Mercedes-Benz SLK
Re: Lift Collapse - 71 Hemi Cuda [Re: BloFish] #2677722
07/15/19 05:48 PM
07/15/19 05:48 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Sad... frown
Re: Lift Collapse - 71 Hemi Cuda [Re: ChryCoGuy] #2677741
07/15/19 06:34 PM
07/15/19 06:34 PM
ga
ringo440 Offline
ringo440  Offline
ga
I have a friend with a lift very similar to that one. When you go to lower the car you must pay attention that all the locks have released. I have been present when he lower the car and one of lock didn't released . He was talking to me and paying attention and let car down a foot before he realized it had not released just lucky it didn't turn out like this guy's car. That what it looks like happen here.
Re: Lift Collapse - 71 Hemi Cuda [Re: ringo440] #2677812
07/15/19 11:17 PM
07/15/19 11:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The lift style is a portable lift which does not require it being bolted down. As far as the locks releasing or not when lowering it, that's a possibility, especially if the cables were not adjusted properly.
Re: Lift Collapse - 71 Hemi Cuda [Re: ScottSmith_Harms] #2678048
07/16/19 07:13 PM
07/16/19 07:13 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Looks like the cable snapped, but the locks should of held it up if the locks were on the posts..but then again, the posts were not bolted down so they slipped away..at least that's what it looks like to me..the damage does not look too bad
Re: Lift Collapse - 71 Hemi Cuda [Re: AARCONV] #2678066
07/16/19 08:38 PM
07/16/19 08:38 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Whatever brand of lift it WAS......he's got at least 2 more of em sitting there. It has those cheesy lock ladders like a Bend Pak, but it's definitely a knock off. My 4 post lift doesn't bolt down either, but it's a lot heavier made than that one, plus it was made out of USA steel, and built in Missouri. Although I do walk around it and check all 4 locks before getting under something I have lifted, I don't worry about it falling. Whoever that guy is, he must be a Cuda man. He's got a building full of them. The car that fell got the passenger fender and door hammered pretty good, but hopefully that's about it.
small block timing chain ?
by calrobb2000. 06/05/20 02:39 PM
1974 dodge dart - $800
by FM3_1970. 06/05/20 01:06 PM
1969 gTx - brown
by Not yr uncle Bob. 06/05/20 12:30 PM
Well....... that seemed worth doing
by fast68plymouth. 06/05/20 12:25 PM
Moparts Recent Posts
by fast68plymouth. 06/05/20 03:11 PM
Old pictures
by bigdad. 06/05/20 03:05 PM
543 440 Combo's
by fast68plymouth. 06/05/20 02:51 PM
