Re: Car door sticks out on bottom
[Re: 6PAX]
#2677632
07/15/19 01:08 PM
07/15/19 01:08 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Open the door, stick a wood 2 X 4 (wrap it in a rag) between the door and the quarter panel at the top and push in on the bottom of the door with your leg. You'll be surprised how much you can warp the door with body power alone.
[Re: John_Kunkel]
#2677698
07/15/19 04:03 PM
07/15/19 04:03 PM
Posts: 4,916 new berlin wisconsin
Mr T2U
collision tech for over 30 years. is this problem just happen or are you replacing or repairing doors? the first place to start when aligning a door is the front lower rocker panel and the top by the windshield and cowl area. these areas are not adjustable. you can always move the fender to fit later. or possibly adjust the 1/4 panel and weld later. but everything starts at the cowl. another thing to remember is these cars are OLD. panel fit and tolerances were significantly different compared to today's cars so the gaps will never be perfect without twisting, bending, and even welding to make things fit. it's a compromise so keep that in mind. also what condition are the hinges in? you will be spinning your wheels if the hinges are not in good shape before adjusting metal.
perception is 90% of reality
