Flywheel for 5.9 Magnum
#2677469
07/15/19 12:39 AM
07/15/19 12:39 AM
Posts: 10,765 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Ok...My boys (14 & 12) are swapping a 5.9 Magnum (converted to carb) in place of the old LA 318 in their ‘64 Sweptline. Truck has a a833OD with a special Hyd. Clutch Bellhousing and a 143tooth neutral balance Flywheel (Flywheel only has maybe 30 miles on it).
Here’s where it gets tricky....I was hoping to just add a McLeod magnum bolt on balance weight (I bought the weight awhile back) to my current non-McLeod internally balanced flywheel (will have a machine shop place the holes for the bolts)...anyone have a template for where this weight would go?
2nd choice (due to cost)...is there a 143tooth 5.9 magnum balanced flywheel off the shelf that will work for this application? Anyone know if a stock 5.9 magnum flywheel will work? Not sure what size clutch the stock magnums use...but I have brand new 10.5 and 11 clutch setups I can use in the garage.
rvoyles
Re: Flywheel for 5.9 Magnum
[Re: Quicksilver440]
#2677504
07/15/19 08:29 AM
07/15/19 08:29 AM
Posts: 7,894 Benton, IL.
DaveRS23
Benton, IL.
I have a copy of a template for drilling the stock flywheels for balance. I think that it is for balancing the more common small block flywheels to the 360. But I have had it so long that I am not sure.
I can find it and post it later if that would help. It is very specific as in a machine shop will need to drill the 3 holes.
KOS
[Re: DaveRS23]
#2677611
07/15/19 12:35 PM
07/15/19 12:35 PM
Posts: 4,386 nowhere
Sniper
nowhere
PERFECTION CLUTCH 502754 143 tooth Magnum 5.9 $85
[Re: DaveRS23]
#2677797
07/15/19 09:52 PM
07/15/19 09:52 PM
Quicksilver440
Central Valley, CA.
Thanks Dave.I have the one for a regular 360...but haven’t seen one for 5.9 magnum when has a different balance...if you have that info, i’d Love to have it!
[Re: Sniper]
#2677798
07/15/19 09:55 PM
07/15/19 09:55 PM
Quicksilver440
Central Valley, CA.
Thanks sniper....that’s an option too...would require me to buy a new clutch setup though....and I’m not positive it would work with my bellhousing (uses a 11” clutch now).
