Re: Recycled 5.7Hemi
[Re: Ray408G3Hemi]
#2677209
07/13/19 10:55 PM
07/13/19 10:55 PM
Posts: 2,255 IL
furious70
IL
Why would they go into the bottom end and not put more cam in it?
Which front cover does a Jeep 5.7 get?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2677262
07/14/19 09:08 AM
07/14/19 09:08 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Good Question , I'm headed over to Ric's place in an Hour for some dyno work , I'll ask him....Do you have a certin year you want to know?
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: furious70]
#2677268
07/14/19 09:16 AM
07/14/19 09:16 AM
Ray408G3Hemi
Springtown Pa
Why would they go into the bottom end and not put more cam in it? I asked the same question, that and the Mod man intake, they would of been better off with the OCP intake and the FAST system. Ric had a stock 04 long block with Crower Cam #33492 .505/.528 lift 206/213@50 114LSA OCP intake F.A.S.T system 465HP was the best pull , I think the RPM was 55 or 5700.
[Re: Ray408G3Hemi]
#2677269
07/14/19 09:16 AM
07/14/19 09:16 AM
Posts: 2,255 IL
furious70
IL
Eagle 09 and up. Did any of them come with the nag1 or only the truck trans?
[Re: furious70]
#2677275
07/14/19 09:38 AM
07/14/19 09:38 AM
Ray408G3Hemi
Springtown Pa
I think the stopped useing the NAG1 when they became FCA ,
[Re: Ray408G3Hemi]
#2677279
07/14/19 10:00 AM
07/14/19 10:00 AM
Posts: 2,255 IL
furious70
IL
Nag1 continued in cars until they got the tf-8 program up and running with enough volume to cover the v8 application. I want an eagle/nag1 combo for my fury with ac and ps and all. I think the truck front cover of better for that but a car lift out is what I'd been looking for to get the nag1. Now I'm wondering about Jeep applications.
[Re: Ray408G3Hemi]
#2677918
07/16/19 12:25 PM
07/16/19 12:25 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I saw it and there is another new vid on it today... but I just don't get why you buy a 50k engine then tear it all down to just reassemble basically stock other than an intake/water pump.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: HotRodDave]
#2678171
07/17/19 07:28 AM
07/17/19 07:28 AM
Posts: 52 Texas
03heavy
Texas
Working on it This is a bge I swapped the reluctor ring , ran the engine with a carb And the msd 6013 ignition controller I need some headers and a center sump oil pan to actually use it in the car I’ve really considered running the engine stock with maybe a srt cam just to see What type ET’s it could produce
[Re: Ray408G3Hemi]
#2678614
07/18/19 11:17 AM
07/18/19 11:17 AM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
I don't usually come over here so excuse me but......... You guys do realize you're looking at episodes that are about 8 yrs old don't you? How much has the aftermarket changed regarding the Hemi in that time?
John
[Re: SattyNoCar]
#2678907
07/18/19 11:17 PM
07/18/19 11:17 PM
Posts: 2,255 IL
furious70
IL
I don't usually come over here so excuse me but......... You guys do realize you're looking at episodes that are about 8 yrs old don't you? How much has the aftermarket changed regarding the Hemi in that time? valid, but there were cams back then. And I believe they had compression tests way back then too to determine if it even needed to come apart
[Re: SattyNoCar]
#2678985
07/19/19 09:20 AM
07/19/19 09:20 AM
Ray408G3Hemi
Springtown Pa
I don't usually come over here so excuse me but......... You guys do realize you're looking at episodes that are about 8 yrs old don't you? How much has the aftermarket changed regarding the Hemi in that time? Well, I'm fairly New to the G3 engines, Never was much of a Mopar guy, dabbled with My D100 off and on thru the years, but haven't done thing with it since 08 other then started it move it wash it. I was cruising and the ole Inter webs and came across that Video, which had a published date of 7/12/19 , Sooooooooooo I thought it was a NEW video......And Honestly not sure how much the aftermarket for these have changed ...Not like there is a lot of Info on these engines, Other then Valve seats bad, Rods bad, 6.1 cranks are junk, Blah, blah, blah. both of my younger kids are getting in to these , considering they have been around Fords their whole life, I sure don't want to be "that dad" who blows them off because its' Dodge and not Ford., my 1st Gen Lighting(solid mid 10s) got it's a$$ handed to it last year down at Atco by a Citron Yellow painted Ram...So I became curious....so it may be 8 years old to you...but it's new to me.
[Re: Ray408G3Hemi]
#2678994
07/19/19 09:38 AM
07/19/19 09:38 AM
Posts: 1,548 Michigan
Kiddart
It doesn't matter how old the videos are or who posted them. the concept is still the same. this is a great platform to play with. I am hopefully about a week away from firing mine up. life has gotten in the way over the last year and progress has been slow. But very excited to drive this hotrod and get 15 to 20 mpg. the info is getting better and better on these motors.
Thank you Kiddart
[Re: Kiddart]
#2679250
07/19/19 10:15 PM
07/19/19 10:15 PM
SattyNoCar
My pointing out the video being 8 yrs old wasn't meant as a bash. As mentioned, some of you honestly didn't know. My intent was nothing more than if you are doing a build and want to copy them, know that you're looking at (now) old products. Nothing more, nothing less. If you learned something from the video, great! A lot of these cable shows are now being re-released 'as new' on YouTube.
John
