Re: 65 Coronet information
[Re: stroked470]
#2676591
07/11/19 03:19 PM
07/11/19 03:19 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Use a lokar cable system for your t.v. and they do make a shroud for your year. mancini has them.
JAKES AUTOMOTIVE
[Re: DoubleD]
#2676755
07/12/19 09:59 AM
07/12/19 09:59 AM
Posts: 4,101 Yes
sixpakdodge
Yes
You need the shroud from a '70-up 6-Cylinder A-body, with Air Conditioning. That is what I use in my '65. I am running the radiator from the same application as well, re-cored as a 4-row. No clutch fan, 160 thermostat, stock '70 440-6. I've driven the car all over the place...PA, OH, MD, DE...only gets above 200 in traffic. Normally runs between 175-185 in regular driving, dependent on the ambient temperature. I also have a 3.23 gear.
The Lokar kit will work for the kickdown. I have used the Bouchillon Kits as well successfully.
[Re: stroked470]
#2676793
07/12/19 12:19 PM
07/12/19 12:19 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
I've been told by Dave Smith at Pro Trans to use the Buchillion (SP?) kick down cable instead of the other brands out there. On your deal if you have the 1965 kick down linkage I would try that first though, I've only seen two different versions of the stock kick down linkage on B body cars. A one piece single rod that is adjustable on one end and a three piece set up including the rod from the carb to the throttle cable bracket The three piece set up has bell crank on a screw in stud that goes into the tranny case with a rod from the bottom end to the kick down lever and another up to the bell crank on the throttle cable bracket that hooks onto the rod to the carb. from the top bell crank I had two 1965 Coronet, one 440 and one 383 500 4 speed car, the 440 car had no motor or tranny in it when I bought it and I can not remember which parts I put in that car to sale it, 440 motor with a 727 I think
