Re: Bronze drive gear and bronze sleeve?
[Re: BradH]
#2677855
07/16/19 08:35 AM
07/16/19 08:35 AM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run. Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!! Bet it would cost me more than $10 to have someone machine my gear to use the $.25 washer, since I don't have the equipment to do it myself. Maybe you need to make some friends !!!
[Re: Stanton]
#2677915
07/16/19 12:23 PM
07/16/19 12:23 PM
BradH
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run. Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!! Bet it would cost me more than $10 to have someone machine my gear to use the $.25 washer, since I don't have the equipment to do it myself. Maybe you need to make some friends !!! I hear ya'. I lost my access to a Smithy when I moved my stuff out of a shared shop when my wife & I bought our house 20 years ago. Never thought I'd need to use it often enough to justify buying one for myself, and don't think that's really changed. It's only times like this where it would be handy to have it right there to knock out simple mods.
[Re: Stanton]
#2678283
07/17/19 12:41 PM
07/17/19 12:41 PM
Posts: 422 montana
BANDIT
montana
Where do you get the 25 cent Torrington washer from? Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2678286
07/17/19 12:48 PM
07/17/19 12:48 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
Where do you get the 25 cent Torrington washer from? Jim Jim, I was wondering that also. I am also amazed that a Torrington roller thrust washer wouldn't brinnel a soft mating surface like brass.
[Re: squirrel]
#2678619
07/18/19 11:28 AM
07/18/19 11:28 AM
Posts: 422 montana
BANDIT
montana
I have a Smithy, so the machining isn’t a problem, was just wondering where to get washer. McMaster-Carr I guess is good as place as any to start. My Indy block actually had too much distance between bushing face and distributor mount surface, I took a little off of the bottom of the distributor to keep gear from moving so much. Jim
[Re: squirrel]
#2678756
07/18/19 05:02 PM
07/18/19 05:02 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think he meant the Torrington washer (the smooth race), not the Torrington thrust bearing (the thing with rollers). The washer is kind of thick for this application, facing the thrust surface of the gear in a lathe would be a good idea if you go that route? Exactly. The washer is .030 thick and smooth enough to run a bearing on so is sure as hell won't harm either the gear or the bushing. I buy them at local bearing supply shops - an "off the shelf" item.
[Re: second 70]
#2678758
07/18/19 05:03 PM
07/18/19 05:03 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I checked this one that I changed out a few years ago and it has wear with a lip on bottom of gear but also the shaft is worn too. The lip and shaft are the least of your worries ... look at the wear on the gear !!!!
[Re: Stanton]
#2678761
07/18/19 05:08 PM
07/18/19 05:08 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Do you have a brand and part number for those good washers?
[Re: Stanton]
#2678762
07/18/19 05:10 PM
07/18/19 05:10 PM
Cab_Burge
I checked this one that I changed out a few years ago and it has wear with a lip on bottom of gear but also the shaft is worn too. The lip and shaft are the least of your worries ... look at the wear on the gear !!!! That gear is worn out
[Re: Cab_Burge]
#2679067
07/19/19 12:09 PM
07/19/19 12:09 PM
Posts: 1,708 central il.
second 70
central il.
I checked this one that I changed out a few years ago and it has wear with a lip on bottom of gear but also the shaft is worn too. The lip and shaft are the least of your worries ... look at the wear on the gear !!!! That gear is worn out I totally agree.This was my first time using one and was surprised how fast it wore out. It only had 3,000 street miles on it. I added a collar now and check it much more often.
[Re: second 70]
#2679071
07/19/19 12:15 PM
07/19/19 12:15 PM
BradH
I checked this one that I changed out a few years ago and it has wear with a lip on bottom of gear but also the shaft is worn too. The lip and shaft are the least of your worries ... look at the wear on the gear !!!! That gear is worn out I totally agree.This was my first time using one and was surprised how fast it wore out. It only had 3,000 street miles on it. I added a collar now and check it much more often. Has restricting the gear movement w/ the collar showed reduction in wear?
[Re: second 70]
#2681026
07/24/19 08:32 PM
07/24/19 08:32 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I replaced the gear and bushing last week.They were in there for 7 years,,over 50k miles and were plain wore out! Todd has them in stock. No spacers or bearings and the bushing has the oil grooves. Al can the new bushing be installed with engine in car and cam still installed? Absolutely.
[Re: Stanton]
#2681139
07/25/19 08:56 AM
07/25/19 08:56 AM
BradH
I replaced the gear and bushing last week.They were in there for 7 years,,over 50k miles and were plain wore out! Todd has them in stock. No spacers or bearings and the bushing has the oil grooves. Al can the new bushing be installed with engine in car and cam still installed? Absolutely. There should be a thread from the last 4 to 6 months that talked about what tools can be used to remove & install the tower bushing.
