Re: Bronze drive gear and bronze sleeve?
[Re: squirrel]
#2675936
07/09/19 11:36 AM
07/09/19 11:36 AM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
If 'sleeve' is referring to the intermediate shaft bushing.....
In my humble opinion, the bottom of the gear and top of the bushing wear together poorly.
That's not to say it doesn't work LOL. No, It works just great. Change the oil often, you won't have any problems.
I have heard of the parts being machined to accept a bearing (torrington washer) to stop the wear.
Although I already pressed on a bronze gear for my latest build, I'm thinking about pressing it right back off again and trying Melonized.............
Rich H.
Esse Quam Videri
[Re: squirrel]
#2675952
07/09/19 12:08 PM
07/09/19 12:08 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Hi, just curious when you use a bronze gear on a billet roller cam, and a bronze sleeve to support the gear, what is supposed to keep them from wearing against each other?
Oil I ran one(Milidon gear on a Pioneer bushing) on my old pump gas car with no wear problems for over 3000 miles and hundreds of 1/4 and 1/8 mile races I recently had a Mopar brand oil pump drive with bronze gear wobble horribly in the block, It was bad enough to make the distributor move around when running or on the starter Bad parts are out there so make sure yours is not one of them
[Re: squirrel]
#2676008
07/09/19 02:43 PM
07/09/19 02:43 PM
Posts: 11,494 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Shim. There used to be a shim kit sold that was used to adjust clearance/end play on the shaft to reduce erratic timing. Although I never saw wear there being an issue on anything I had. Maybe need to check and make sure that the distributor shaft is not loading the gear against the bushing for some odd reason.
[Re: squirrel]
#2676023
07/09/19 03:55 PM
07/09/19 03:55 PM
ZIPPY
S.E. Michigan
that's the problem, I have been changing the oil often, and the gold colored sparkly things are disheartening. At least I think I know where it's coming from.
Understood and yes, I agree it is easily observed. If you take a minute and pull the intermediate shaft out and have a look at the bottom You'll probably also notice the parts marking each other up. This seems to do no harm, but it is far from optimum. There are so many other things to be concerned with that this often goes overlooked even though many of us are aware.
Rich H.
Esse Quam Videri
[Re: squirrel]
#2676025
07/09/19 04:09 PM
07/09/19 04:09 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Does your bushing have oil grooves on the top flange?
So do....... some don’t.
[Re: squirrel]
#2676026
07/09/19 04:09 PM
07/09/19 04:09 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I haven't seen them for sale, but I haven't looked everywhere yet. I know there are plastic gears for Chevys (they were OEM on some engines). I'm working on a 426 Hemi.
I was pondering adding a thin hard steel shim between the two soft parts, so they won't want to gall.
I used a valve spring shim for a motorcycle on my small block build and in two years have never had any shiny brass in my oil or filter. IIRC it was .014' and I didn't cut anything.
[Re: justinp61]
#2676029
07/09/19 04:26 PM
07/09/19 04:26 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
I haven't seen issue with the bushing to gear wear on my small block. I was surprised on my last inspection to discover that the bronze bushing in the block was totally smoked. I replaced it and added a small hole to the galley plug to give the area a direct shot of oil. I have no idea if this will help or if you can do this on a big block/Hemi.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2676034
07/09/19 04:33 PM
07/09/19 04:33 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I like the idea of the torrington washer between the two parts. A very simple solution to an ongoing annoyance. Thanks
[Re: fast68plymouth]
#2676053
07/09/19 05:37 PM
07/09/19 05:37 PM
Posts: 147 AZ
squirrel
AZ
So do....... some don’t. Yes, it does.
[Re: squirrel]
#2676705
07/12/19 01:40 AM
07/12/19 01:40 AM
Cab_Burge
I have noticed shiny particles in the oil drained from my vacuum pump puke tank every time I drain it, twice a day at the races on my new motor so I decided to look at the gear, it was a new Mopar brand and it is making metal since start up evidently This motor has a set of Jesel paired shaft rocker arm set up on the 440-1 heads so I don't want it failing, I reused the one out of the old motor that has 5 + years of racing on it with no issues or evidence of wear on it yet I'll watch it carefully now and hope it doesn't start wearing against this camshaft
[Re: Cab_Burge]
#2676844
07/12/19 03:34 PM
07/12/19 03:34 PM
Posts: 765 Midwest
fuseable
Midwest
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run.
[Re: fuseable]
#2677688
07/15/19 03:37 PM
07/15/19 03:37 PM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run. Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!!
[Re: Stanton]
#2677770
07/15/19 08:28 PM
07/15/19 08:28 PM
BradH
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run. Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!! Bet it would cost me more than $10 to have someone machine my gear to use the $.25 washer, since I don't have the equipment to do it myself.
