Re: Clearancing push rod holes
[Re: 440mopar]
#2669581
06/24/19 09:21 PM
06/24/19 09:21 PM
Posts: 14,937 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A double cut is easier to control and takes smaller bites. I usually recommend either turning down the air pressure or better yet getting a router control at Harbor Freight for you electric grinder. Keep your burr clean buy dipping it in transmission fluid or wd40. Lots of ways to go about it but that will get you started. If you need burrs quickly Summit sells them.
1970 Duster Edelbrock headed 408 6.143@110.85 mph 9.73@135.05 mph shifting at 6700 RPM 422 Indy headed small block 5.982@112.56 mph 9.42@138.27
[Re: ZIPPY]
#2669706
06/25/19 08:26 AM
06/25/19 08:26 AM
Posts: 7,154 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Buy the burr for cutting aluminum, not steel This is the best advice !! Aluminum cutters are much coarser so they don't clog as easily. I have used the cutters that all those chinese tools vendors sell at the swap meets with no problems. You'll also need cutters with a long stem to reach where you need to cut so get ones with 6" stems.
[Re: Stanton]
#2669725
06/25/19 09:15 AM
06/25/19 09:15 AM
Posts: 11,996 north of coder
moparx
Dreaming of implants
also, bar soap works for a lube. best stuff, [in my opinion, your mileage may vary] is machinist's wax. works super on aluminum using course cutters at a somewhat slow speed. most guys crank the speed to max, but slow and steady does the best job. make sure to use eye and face protection ! if not, "You'll take yer eye out, kid !" [to paraphrase a popular movie saying.  ]
[Re: 440mopar]
#2669728
06/25/19 09:24 AM
06/25/19 09:24 AM
Posts: 3,748 northern,Ohio,USA
Clanton
northern,Ohio,USA
Did you think about opening the oil drain holes?I used a 1/4 double cut bit 4" long on both
[Re: Clanton]
#2669875
06/25/19 05:28 PM
06/25/19 05:28 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
make sure to use eye and face protection Another piece of VERY good advice !! Whenever I do ANY grinding with burrs I always wear long sleeves and welding gloves with the sleeves tucked in. Those little pieces of metal are sharp as hell and fly everywhere. Welding gloves are thick enough the shards won't penetrate.
[Re: 440mopar]
#2669972
06/25/19 08:48 PM
06/25/19 08:48 PM
Posts: 3,355 New York
polyspheric
New York
Remember that (although it's frequently the easiest way) a larger round hole does not track the actual path of the pushrod tube as it cycles. The relief hole's actual shape has a length (on the crank axis) of the tube OD + safety margin, but the cross (left-right) axis is 2 holes this size joined by a relief that allows the full in-out swing of the rocker arm (not an ellipse, the sides are parallel). This will depend in part on your rocker ratio - high ratio rockers are commonly made by shortening the tappet (short) lever, which increases the sweep of the adjuster. If you're copying a known-to-be-safe similar engine, beware of cam & rocker differences.
Boffin Emeritus
[Re: polyspheric]
#2670101
06/26/19 08:34 AM
06/26/19 08:34 AM
Clanton
northern,Ohio,USA
Remember that (although it's frequently the easiest way) a larger round hole does not track the actual path of the pushrod tube as it cycles. The relief hole's actual shape has a length (on the crank axis) of the tube OD + safety margin, but the cross (left-right) axis is 2 holes this size joined by a relief that allows the full in-out swing of the rocker arm (not an ellipse, the sides are parallel). This will depend in part on your rocker ratio - high ratio rockers are commonly made by shortening the tappet (short) lever, which increases the sweep of the adjuster. If you're copying a known-to-be-safe similar engine, beware of cam & rocker differences. Well said.I have center located push rods in the roller lifter 1.5 rockers.I opened the oil drain holes to help from the head gasket and after market block covering a lot of the holes open area but I think it would help in any case.
[Re: dthemi]
#2671065
06/28/19 10:09 AM
06/28/19 10:09 AM
Posts: 12,081 Great Neck,LI,new york
hemi-itis
Someone needs to invent rat tail file pushrods. Put'm in, crank it, clean the oil filter, and go cat go lol.  That WOULD work! Terry Manton told me years ago I only need 10 thou of clearance as the flexing could use the help!
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
[Re: 440mopar]
#2675798
07/08/19 10:58 PM
07/08/19 10:58 PM
Posts: 15,241 Val-haul-ass... eventually
BradH
I almost got away with it!
How good are your grinding skills? Stick with the smaller bit, if there's any doubt. Or, depending upon how much material needs to be removed, use cartridge rolls to slow down the process enough to avoid removing too much too fast.
That's it! No more Mr. Nice G-... Oh, look at the at adorable puppy! Come here little guy! Want me to scratch you behind your floppy little ears? I love puppies, they're SO CUTE! Bye-bye little fuzz ball!
Now, what was I saying?
[Re: 440mopar]
#2675836
07/09/19 02:57 AM
07/09/19 02:57 AM
Posts: 1,912 Milwaukee WI
TRENDZ
Milwaukee WI
Been away on vacation so I haven't worked on clearancing the pushrod holes yet but I plan on picking up a bit this week. I will get a bit for aluminum but have one more question. Should I get a 1/2" diameter bit (the size of the pushrod hole), insert it in the hole and just work it upward till I have the needed clearance (basically ovaling the hole vertically) or would it be better to do the same but use a smaller diameter bit like 3/8" (the size on sizediameter of my pushrods) and just notch the hole at the top where the pushrod is making contact? I hope my question makesze sense. You can’t be size on size with a burr bit. The bit always needs to be smaller than the radius, or you will get impossible to control chatter.
[Re: TRENDZ]
#2675884
07/09/19 08:17 AM
07/09/19 08:17 AM
hemi-itis
Terry Manton told me that 10 thou is all that's needed at it's closest point.It will act as a guide
[Re: 440mopar]
#2676094
07/09/19 07:51 PM
07/09/19 07:51 PM
Posts: 257 Eden, UT
1KoolBee
Eden, UT
I need to clearance the push rod holes on my Eddy heads and have to buy a bit for my hand grinder to do so. Would like to know what type of bit works best. Should I get a single cut cylinder bit or a double cut or perhaps something else? What rockers are you using? I found that when I went to Harland Sharps for Edelbrock Heads on my Stealths, the material removal needed to clearance the pushrods was dramatically reduced. Fixed the scrub pattern too.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana
[Re: 1KoolBee]
#2676177
07/10/19 08:28 AM
07/10/19 08:28 AM
Posts: 698 USA
440mopar
USA
What rockers are you using? I found that when I went to Harland Sharps for Edelbrock Heads on my Stealths, the material removal needed to clearance the pushrods was dramatically reduced. Fixed the scrub pattern too. Comp Pro Magnums.
[Re: 440mopar]
#2676184
07/10/19 09:07 AM
07/10/19 09:07 AM
Posts: 51,363 Romeo MI
MR_P_BODY
I've learnt over the years to use tootsie rolls to do this.. on my B1 I could use the mill and a end mill but I had a lot to take out.. seldom do I ever use a alum cutter in a air grinder.. its to easy for it to wobble around the hole and it takes too much material off to quickly(I would rather use a steel cutting bit which is much easier to control
