What size fuel sending unit for 340-6? 3/8 or 5/16 #2675766
07/08/19 10:29 PM
07/08/19 10:29 PM
NW/Indiana - Chi town
ricomondo Offline OP
I'm looking to see what size fuel sending unit for 340-6 please? 3/8 or 5/16?
Need to replace the tank/sending unit. The line on there currently, the size is unreadable. Again this is for the sending unit from the tank.
GY3 71 Demon 340
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: ricomondo] #2675777
07/08/19 10:52 PM
07/08/19 10:52 PM
New York, USA
Chargerfan68 Offline
New York, USA
I would think it would match the feed line to carb. See if you can measure the feed line and get that size.
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: Chargerfan68] #2675800
07/09/19 12:02 AM
07/09/19 12:02 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think the fuel line was consistent rear to front on all Mopars of that era, judging from the ones I've worked on.
Try to get a measurement by whatever method:
1. Calipers/"dial indicator"
2. Reading a hose if any of the printing is visible
3. Slit a short length of 5/16 & 3/8 hose, slip it over the line and observe proper fit.
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: topside] #2675816
07/09/19 12:34 AM
07/09/19 12:34 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Stock is 5/16" which works fine even in higher HP applications.
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: ScottSmith_Harms] #2675865
07/09/19 08:17 AM
07/09/19 08:17 AM
Likely 5/16 if OE but you could slip an open ended 5/16 wrench on the steel nipple coming out of it. New sending units are the worst of the worst for reading off & see if you can pull up prior threads regarding this for some good companies to deal with or just scroll back a few days to a week (I think there was a recent comprehensive thread on this awhile back).
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: RapidRobert] #2675897
07/09/19 09:58 AM
07/09/19 09:58 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Less restriction on the suction side of the pump is always a plus. Go 3/8" and you will have room to grown with basically no down side other than any price difference and maybe a tiny but more attention to detail during installation.
I know when I converted to EFI the instructions required 3/8" feed line and you reused the original 5/16" line as the return to the tank.
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: Sniper] #2675938
07/09/19 11:42 AM
07/09/19 11:42 AM
Quote
X2
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: RapidRobert] #2676100
07/09/19 09:11 PM
07/09/19 09:11 PM
Thanks everyone!
GY3 71 Demon 340
Re: What size fuel sending unit for 340-6? 3/8 or 5/16 [Re: ScottSmith_Harms] #2676101
07/09/19 09:12 PM
07/09/19 09:12 PM
Thank you Scott! I'm gonna go with 5/16
GY3 71 Demon 340
