leaf spring compatibility #2675513
07/08/19 12:31 PM
07/08/19 12:31 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
Need to know if a pair of factory HD leaf springs from a 1972 'Cuda will fit a 1969 Road Runner? ( Bolt hole-to-bolt hole length). Thanks for the help.
Re: leaf spring compatibility [Re: 69/70 Plymies] #2675626
07/08/19 04:56 PM
07/08/19 04:56 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, short answer , nope. your e body has a shorter rear section .ronnie drive
Re: leaf spring compatibility [Re: 1969ronnie] #2675668
07/08/19 06:12 PM
07/08/19 06:12 PM
Andrewh Offline
Andrewh  Offline
it won't but andyF makes and firmfeel sells extended front hangers so a b-body can use e-body leafs.
Re: leaf spring compatibility [Re: Andrewh] #2675718
07/08/19 08:40 PM
07/08/19 08:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Both have a 22" front spring section (center pin to center of front spring eye).
E-body rear section (center pin to center of rear spring eye) is 35", that era B is 36".
The shorter rear section will cause the rear shackles to either be vertical or point forward at the bottom.
Not a problem for rolling around the shop, but the springs will not work properly and the car should not be driven that way.
Using an extended front mount in the OP's scenario will move the center pin back, which moves the axle back (and the driveshaft @ ft yoke/trans).
Those front mounts are typically for using the 20" ft section SS springs in cars that have 21" or 22" section stock.
Re: leaf spring compatibility [Re: topside] #2675776
07/08/19 10:49 PM
07/08/19 10:49 PM
New York, USA
Chargerfan68 Offline
New York, USA
Good information and explaination. I agree from what i’ve learned over the years. up
Re: leaf spring compatibility [Re: topside] #2675801
07/09/19 12:03 AM
07/09/19 12:03 AM
midwest - USA
midwest - USA
Topside,
Thank you very much for the detailed information. You have helped me and I'm sure others, as well.
Re: leaf spring compatibility [Re: 69/70 Plymies] #2675805
07/09/19 12:07 AM
07/09/19 12:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Glad to help; ya do a couple dozen of these things, ya learn stuff ! laugh
