Cheap 318 build help
#2675097
07/07/19 08:09 AM
07/07/19 08:09 AM
Posts: 523 Right here
HP2
Right here
Just want to put a cheap engine together to haul around with in my 70 Sweptline. I enjoy being cheap and buy as little as possible. Haven't any experience from 318's so I need some advice. Truck is a Power Wagon with manual tranny. Want to wake her up a little. Don't want a screamer, just some more grunt.
I have the original 318 coming out today. It barely runs. Checked compression and it has all from 80-90 to 145 psi. I plugged in compressed air and listened for valve leaks but they seemed to be okay. 2bbl carb needs job. Original points ignition. The other engine is from the late 80's with roller cam and swivel closed chamber heads. Did a leak down test before I took it apart and it has bad leaking valves. Bores look pretty good (for my purpose). Some home honing and new rings will be needed regardless what block I use.
The original exhaust manifolds will stay on. I have some LA 4-bbl intakes and a bunch of different carbs. Will buy new cast iron rings but bearings only if needed. Hope to be able to use some of the original valve springs.
Are the swivel heads a better choice than original or will the compression ratio be too high? Summit have cam kits for 120 dollars for the older engine, what cams should I look for for the newer roller cam engine?
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
Re: Cheap 318 build help
[Re: B1MAXX]
#2675258
07/07/19 04:59 PM
07/07/19 04:59 PM
HP2
Right here
the compression with the swirl heads will be better, don't forget you'll be replacing a stock .018 shim gasket with a .040 composite. For the roller cam I would get one for a same year 360 from sealed power, probably less than 100 bucks. reuse the lifters. I have gone thru the engines today I have decided to use both short block and heads from the 80's engine. Bores are better and will be nice with a honing job. Have put some work into the heads and valves should be tight and sealing now. Maybe should go with the .018 head gasket again to not loose any comp? I can't find the cam you mention... would finding someone who can regrind the cam be an option?
[Re: dogdays]
#2675410
07/08/19 12:57 AM
07/08/19 12:57 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I think I remember reading that the 318s of that era had more compression than the 360s (around 9.2:1, advertised). The heads will be fine but you may need new valve springs with a different cam. Roller cams are not cheap. How much is a basic set of 1.6 roller rockers? The 360 TBI cam was also used in the first 360/300 magnum crate motors but it had the benefit of the 1.6 ratio rockers. It's not a performance grind, it's a stump puller. The factory magnum cams aren't much better and don't have a fuel pump eccentric (but the 360 TBI does). Buy a three way timing chain.
The other option would be to just install a traditional hydraulic cam. A stock 340 cam was always considered the best upgrade for a 318, although there are more grinds out there now. That means giving up the roller feature though. All depends on your budget and what you are comfortable with. I am in the same position with a stock rebuilt 360 roller motor and I think I'm just going to leave it alone. It's barely broken in and any changes are just going to snow ball. It's not going to blow anyones doors off but it'll be reliable and have good torque. I'm going to put in a 'warm' converter and some decent gears and chase the dragon that way.
If you don't mind the weight, the factory 340 4bbl manifolds work just fine. Another good option would be an older edelbrock 318-360 performer.
[Re: Montclaire]
#2675436
07/08/19 08:26 AM
07/08/19 08:26 AM
HP2
Right here
If you don't mind the weight, the factory 340 4bbl manifolds work just fine. Another good option would be an older edelbrock 318-360 performer. I have googled some more and it seems to be too expensive to get better performance with a roller cam. Since I'm cheap and I'm not gonna put a lot of miles on this engine I have started leaning against a flat tappet hydraulic cam. I have been looking at this one, I think it could do the job and costs only 150 including lifters: https://www.summitracing.com/int/parts/sum-k50052/overview/make/dodge Questions: will the lifters just drop in, and can I use the pushrods from the 1970 318" in my circa 1987 roller cam 318"? I know it won't be correct and by the book but can I use the 1970 valve springs with the Summit cam? I'll check for binding first of course. This engine will never see higher rpm's. I'll check today what intakes I have. I know for sure I have a couple of stock and heavy 4-bbl's so I guess that will be good enough. Weight is no issue on a 4,600 pound truck I have started lapping the valves on the 302 heads now so they should soon be ready to go. They would benefit of some porting but I don't have the time (and I hate porting iron heads), will just match port.
[Re: HP2]
#2675476
07/08/19 11:00 AM
07/08/19 11:00 AM
Montclaire
Scranton, PA
As far as I know it will all bolt up but be careful not to mix and match lifters and pushrods roller/non-roller. I know that with the magnum heads the pushrod length changes.
[Re: HP2]
#2675515
07/08/19 12:34 PM
07/08/19 12:34 PM
Posts: 1,965 Apollo, PA.
B1MAXX
Apollo, PA.
the compression with the swirl heads will be better, don't forget you'll be replacing a stock .018 shim gasket with a .040 composite. For the roller cam I would get one for a same year 360 from sealed power, probably less than 100 bucks. reuse the lifters. I have gone thru the engines today I have decided to use both short block and heads from the 80's engine. Bores are better and will be nice with a honing job. Have put some work into the heads and valves should be tight and sealing now. Maybe should go with the .018 head gasket again to not loose any comp? I can't find the cam you mention... would finding someone who can regrind the cam be an option? cam is CS665
[Re: HP2]
#2675758
07/08/19 10:10 PM
07/08/19 10:10 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
. https://www.summitracing.com/int/parts/sum-k50052/overview/make/dodge [/quote] I used a similar cam in my 318 1977 Power Wagon,it was a Crane grind I believe (Circa 1990).It worked well,mild bowl cleanup in the heads,performer intake and small Holley 600 carb,the truck had 3.55 gears. I don't recall the lobe separation,but I think the lift was .427/.454 in/ex. I did install the cam straight up originally but later advanced the cam for some more low end and it worked well in the 5k pound truck, RT
[Re: 65rbdodge]
#2675866
07/09/19 08:19 AM
07/09/19 08:19 AM
RapidRobert
Just get the right OE pushrods if going roller
[Re: HP2]
#2675871
07/09/19 08:42 AM
07/09/19 08:42 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
[Re: QuickDodge]
#2675894
07/09/19 09:56 AM
07/09/19 09:56 AM
Posts: 6,228 nowhere
Sniper
nowhere
Do the push rods for the flat tappet cams will rub on those late 80's heads? Seems like someone told me that once. Does anyone know if this is an issue? No, it's the other way around. The heads used on roller engines have oversized pushrod holes because they would rub on the earlier smaller holes. But like any build, you should check.
