72 D200 grille repair
#2674889
07/06/19 04:15 PM
07/06/19 04:15 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
My 72 grille is pretty bad (see pics). Any ideas on how to fix it? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 72 D200 grille repair
[Re: T2R9]
#2674951
07/06/19 06:51 PM
07/06/19 06:51 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Have you ever tried to find nice original grilles for these 70's trucks? It is dang near impossible, and when you do find a nice one they want near $1k or more for them.
[Re: Guitar Jones]
#2674957
07/06/19 07:14 PM
07/06/19 07:14 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
They are expensive but if you keep up the search on craigslist and ebay a decent driver quality used one can be found for $300-ish
Facts are stubborn things.
[Re: larrymopar360]
#2674967
07/06/19 07:51 PM
07/06/19 07:51 PM
Guitar Jones
They are expensive but if you keep up the search on craigslist and ebay a decent driver quality used one can be found for $300-ish Hit me up the next time you see a 74 style please.
[Re: Guitar Jones]
#2674972
07/06/19 08:02 PM
07/06/19 08:02 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I already found my '79 quad headlight grille. I paid $300 and it's pretty darn nice. If I come across I will though. I'm always looking at truck parts.
[Re: BDW]
#2675019
07/06/19 09:53 PM
07/06/19 09:53 PM
GTSDart340
Laveen, Arizona
Since you have all the pieces, I would scuff the back. Then take some thin gauge sheet metal or aluminum and use it as a backing plate to epoxy the 2 together. Won’t make the front any better, but from the looks of it you’ll be able to fit it back together and it may just look like a hairline crack from the front. We've done that before with limited luck. I'm not going for show quality, so I don't mind the cracks, what concerns me most is the broken mounting foot. Any suggestions on reattaching that? Thanks!
[Re: GTSDart340]
#2675076
07/07/19 04:56 AM
07/07/19 04:56 AM
Guitar Jones
Maybe a strip of aluminum and some pop rivets.
[Re: GTSDart340]
#2675113
07/07/19 09:37 AM
07/07/19 09:37 AM
Posts: 1,179 Canada
demon
Canada
Since you have all the pieces, I would scuff the back. Then take some thin gauge sheet metal or aluminum and use it as a backing plate to epoxy the 2 together. Won’t make the front any better, but from the looks of it you’ll be able to fit it back together and it may just look like a hairline crack from the front. We've done that before with limited luck. I'm not going for show quality, so I don't mind the cracks, what concerns me most is the broken mounting foot. Any suggestions on reattaching that? Thanks! The mounting foot isn't all that necessary. From 77-80, they eliminated those 4 tabs. Pop rivet the one piece back on and leave the missing one.
[Re: hemi-itis]
#2675343
07/07/19 09:09 PM
07/07/19 09:09 PM
GTSDart340
Laveen, Arizona
The only grille in there is $2k. My truck isn't even worth that... That's why I'm planning on fixing this one.
[Re: GTSDart340]
#2675768
07/08/19 10:31 PM
07/08/19 10:31 PM
Posts: 1,159 Cruising!
QuickDodge
Cruising!
Does anyone still make aftermarket grills for those trucks? Tube grills were popular years ago.
As already mentioned, some guys can weld those grills.
