Re: hemi tone ring
[Re: crazy 340]
#2672791
07/01/19 10:18 PM
07/01/19 10:18 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
How many screws hold the ring on the crank of the 2017? The timing covers are different, different intake etc... I'm sure you can make it work, but your chrysler mechanic friend should have knew this all.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: hemi tone ring
[Re: Silver70]
#2674728
07/06/19 10:06 AM
07/06/19 10:06 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I think the change over from 3 to 4 bolt tone wheel was in 2016, I hooked up my builder up with a pai of police 5.7s both were 2015s , both had 4 bolt tone wheels, but the 5.7 in my daughters 2015 Challenger had a 3 bolt. all were 58 teeth. you can use the 6.1 wheel or any of the aftermarket 32 tooth wheels.. My sons 08 2500 has a 2016, 6.4 in it, had to change the tone wheel while we were in there we did bearings and a new pump left the cam stock , we locked the cam at about 10 degrees retard from the full adavance postion. . had to use the 2016 front cover , mounted the Stearing pump where the 16 had the alt, and mounted the alt where the 16 had the air compressor , he did away with the air condition compressor before he swapped the 6.4 in.......Also FWIW , my 2010 Challenger stroker motor(408CI 4.03X4) is a 03 5.7 block and we used the 2010 VVT front cover....bother VVT and Non VVT timing covers will bolt on to all 5.7s but the older cover won't clear the VVT cam system. both cover have the cam timing sensor in the same spot and relationship to the tone wheel(on the cam gear ) is the same depth.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
