black neoprene valve stem seals, easy Q
#2674615
07/05/19 09:25 PM
07/05/19 09:25 PM
RapidRobert
other than shallow ones for ex valves/deeper ones for intakes, is the fitment the same, in other words will the same press on ones fit any 5/16/8mm/3/8 valve stems? Thank you for your time.
Re: black neoprene valve stem seals, easy Q
[Re: lewtot184]
#2674720
07/06/19 09:59 AM
07/06/19 09:59 AM
RapidRobert
Yes with them being a snug fit I was thinking that they might be universal ex for the special machining you mentioned. If useing the tall ones on the ex also is a good plan I will incorporate that from now on.
