Close up of 70 cuda grill argent/texture? #2673608
07/03/19 02:19 PM
07/03/19 02:19 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I have a mint 70 grill never cracked or repaired. Looking from backside of it...how ever it has been painted metallic silver at some point.can someone post a orignal grill that's not been painted so can see how much texture/sparkle the grill should have
I found some (just spray bomb) that I thought would look close. But maybe the flake is to big? And may be a tad on the bright side?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Close up of 70 cuda grill argent/texture? [Re: toplescuda] #2673882
07/04/19 08:22 AM
07/04/19 08:22 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Frank Badalson sells the closest paint to original appearance that there is. It has a base medium grey with texture then you follow with a semi gloss clear with a ton of metallic in it. Takes a good painter to make sure it comes out even but it is fantastic!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Close up of 70 cuda grill argent/texture? [Re: MOPARMIKE69] #2674184
07/04/19 06:42 PM
07/04/19 06:42 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Im.aware of that people can do it. What I was after was a shot of a unrestored grill showing a close up of it
1971 charger
Re: Close up of 70 cuda grill argent/texture? [Re: toplescuda] #2674218
07/04/19 08:26 PM
07/04/19 08:26 PM
P
Porter67 Offline
Porter67  Offline
P
The pics here might be helpful. Some decent closeups, but id say on this one its on the lighter side of the heaviness of the coat, some were thicker and would of had more flake and stand out a bit more.
https://www.ebay.com/itm/1970-PLYMO...GENT-PAINT-EMBLEMS-2949558/282532226512?
Re: Close up of 70 cuda grill argent/texture? [Re: Porter67] #2674259
07/04/19 10:37 PM
07/04/19 10:37 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Wow. I was thinking my grill had lot more flake then that. Like a gran coupe tail panel but lighter shade
1971 charger
Re: Close up of 70 cuda grill argent/texture? [Re: toplescuda] #2674276
07/05/19 12:05 AM
07/05/19 12:05 AM
P
Porter67 Offline
Porter67  Offline
P
You should clean your pm box out.
Re: Close up of 70 cuda grill argent/texture? [Re: toplescuda] #2674903
07/06/19 04:59 PM
07/06/19 04:59 PM
Sandy, OR
OE Argent Offline
OE Argent  Offline
Sandy, OR
here's a chunk out of production line installed grille... it's a section from up inside the park light area... same part 2 pics different lighting. 3rd Compared to NOS Argent Formula....
original grille argent
same chunk different light
