Oil Pump Pick Up Problem. #2674072
07/04/19 02:59 PM
07/04/19 02:59 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I have a 187 oil pan on my 440 and I’m swapping it out for an a reproduction Hemi oil pan. The sumps are the same depth but the slope on the drain plug side of the sump starts a tiny bit earlier and my pickup hits it. My bolt holes are maybe 3/32 inch off from lining up at most. Can I alter the stock pickup to clear the back of the sump?
Thanks!
I’m listening.
Re: Oil Pump Pick Up Problem. [Re: Big Bad Bee] #2674151
07/04/19 05:44 PM
07/04/19 05:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can buy a pick-up to fit the hemi pan.
Re: Oil Pump Pick Up Problem. [Re: Big Bad Bee] #2674188
07/04/19 06:50 PM
07/04/19 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can do either.. mod the PU or the pan itself
wave
Re: Oil Pump Pick Up Problem. [Re: Big Bad Bee] #2674194
07/04/19 06:56 PM
07/04/19 06:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used the Mopar straight pick up with that pan and it works very nice and plays well with the windage tray.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Oil Pump Pick Up Problem. [Re: lewtot184] #2674280
07/05/19 12:40 AM
07/05/19 12:40 AM
Spokane Valley, WA
Spokane Valley, WA
Right. And when I buy a Hemi pickup, it will be identical to the one I have now because it’s the aftermarket pan that’s the issue. Can you buy pickups that are slightly offset from the original, and if so, where?
I’m listening.
Re: Oil Pump Pick Up Problem. [Re: MR_P_BODY] #2674281
07/05/19 12:43 AM
07/05/19 12:43 AM
Spokane Valley, WA
Spokane Valley, WA
wave
I don’t want to ding the pan and screw up the coating. How do you mod the pickup? Is it safe to grind a section away?
I’m listening.
Re: Oil Pump Pick Up Problem. [Re: fourgearsavoy] #2674282
07/05/19 12:47 AM
07/05/19 12:47 AM
Spokane Valley, WA
Spokane Valley, WA
Gus beer
It’s not the same as that Milodon but if the depth is right I’ll give it a go. Thank you.
I’m listening.
Re: Oil Pump Pick Up Problem. [Re: Big Bad Bee] #2674289
07/05/19 01:29 AM
07/05/19 01:29 AM
Which reproduction hemi oil pan are you buying and want to use, 1966 to 1969 5 quart or the 1970/1971 hemi and 440 six pack 6 quart oil pan? shruggy
Re: Oil Pump Pick Up Problem. [Re: Cab_Burge] #2674481
07/05/19 04:09 PM
07/05/19 04:09 PM
Spokane Valley, WA
Spokane Valley, WA
This one. Which, I started looking. I thought it was a repo hemi pan but apparently it's a 5 quart? Regardless, bigger than my 187. The rear of the pan is deeper than the 187. Sump is almost the same at the base and in the same location. And I am running a windage tray.
I’m listening.
Re: Oil Pump Pick Up Problem. [Re: Big Bad Bee] #2674497
07/05/19 04:32 PM
07/05/19 04:32 PM
Spokane Valley, WA
Spokane Valley, WA
My current pan looks like this.
I’m listening.
