Re: 440 Blocks - Another Poll
[Re: DusterKid]
#2673357
07/02/19 08:20 PM
07/02/19 08:20 PM
Posts: 5,159 CT
GTX MATT
CT
Can you make an option "I haven't cracked one" so we can see the results? I think you should add a "total timing" option.
[Re: DusterKid]
#2673479
07/03/19 06:08 AM
07/03/19 06:08 AM
Posts: 287 PA
Harry's Taxi 2
PA
Stroke, rod length and chamber shape (original wedge or newer heart shape) should also be added.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: DusterKid]
#2674004
07/04/19 01:09 PM
07/04/19 01:09 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2674631
07/05/19 10:16 PM
07/05/19 10:16 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle.. What fuel you burnin ??Is that 18 psi in the intake? Sounds like a kickin effective CR!
[Re: hemi-itis]
#2674714
07/06/19 09:46 AM
07/06/19 09:46 AM
Posts: 4,066 Mo.
racerx
Mo.
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle.. What fuel you burnin ??Is that 18 psi in the intake? Sounds like a kickin effective CR! Also ...how long have you been running this block?
[Re: racerx]
#2674785
07/06/19 11:24 AM
07/06/19 11:24 AM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle.. What fuel you burnin ??Is that 18 psi in the intake? Sounds like a kickin effective CR! Also ...how long have you been running this block? 20 deg timing is the secret to its survival. It will likely live a long happy life with that tune. Kevin
[Re: hemi-itis]
#2674952
07/06/19 06:57 PM
07/06/19 06:57 PM
HOTMOPR
Oakville, Wa
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle.. What fuel you burnin ??Is that 18 psi in the intake? Sounds like a kickin effective CR! . E98
[Re: racerx]
#2674953
07/06/19 07:00 PM
07/06/19 07:00 PM
HOTMOPR
Oakville, Wa
My 440 is 500" 9.5-1 compression spin it to 6700. Makes over a 1000 to the tire at 18 psi and 20* timing. still holding strong.. pretty much a stock block with a girdle.. What fuel you burnin ??Is that 18 psi in the intake? Sounds like a kickin effective CR! Also ...how long have you been running this block? Ya. 18 psi in the intake. In E98. Same engine since 12'
