Page 2 of 17 1 2 3 4 16 17
A12 replica wheels and tires [Re: moparts] #2672685
07/01/19 06:43 PM
07/01/19 06:43 PM
New York
Mopucky Offline
Mopucky  Offline
New York
Up for sale are 4 gloss black 3 nub aftermarket wheels with Firestone G70-15 polyglas tires. These were on an A12 temporarily. Very low mileage on them. Rims are 15x7. Will be for sale at Carlisle if not paid for prior to 7-11
Asking $1400
These are ready to bolt on and go.
PM me here.
**********SOLD**********
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2672752
07/01/19 09:05 PM
07/01/19 09:05 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Rear laser cut trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket, a lock washer, and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included lock washers and nuts, tighten them down and you’re done. Takes about 5 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body’s with the standard shock plates like shown in the pictures. $50.00 per pair plus $8.00 for shipping. I also have these available for cars with CalTracs.
Email mrrandyj@aol.com
I will be going to Chrysler’s at Carlisle if you want to save on shipping and pick them up there.
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2672774
07/01/19 09:30 PM
07/01/19 09:30 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
What we have here is a brand new reproduction voltage regulator for a 1962-1969 Dodge Plymouth or Chrysler vehicle. This regulator looks almost exactly like what the originals look like from the outside, it even has the IGN and FLD stamped into the cover, but hidden inside is a small circuit board with diodes, transistors, and other electronic components. This voltage regulator is completely electronic. No more points that cause voltage fluctuations. Now you can have the best of both worlds, a voltage regulator that looks stock but is all electronic inside. This is a bolt on upgrade, no modifications are necessary. Bolt it on and plug in your factory wiring, its that simple. The cost for these is $28.00 each with free shipping anywhere in the continental US.
If you have any questions you can email me at mrrandyj@aol.com
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2672787
07/01/19 10:07 PM
07/01/19 10:07 PM
NJ
moparply Offline
moparply  Offline
NJ
NOS 1968-70 Charger Roadrunner wiper blade assemblies, Trico 15”, correct early production line assemblies with correct early refills, matched pair in mint condition, $200 pair
NOS 1968-70 Charger Roadrunner Trico wiper blade refills, correct early version, mint condition in their original box’s, $100 pair
Email Kenei@concast.net
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2672798
07/01/19 10:35 PM
07/01/19 10:35 PM
Metro Detroit
6PAX Offline
6PAX  Offline
Metro Detroit
70 RR/GTX short grill molding. $25
70 RR/GTX long bottom of grill molding. $50
68-70 B-body both sides lower windshield moldings. $50 for the pair
New 68-70 B-body under dash insulation. $15
New 1970 B-body glove box liner. $15
New 68-70 B-body chrome door lock button ferrules. $20
Front disk brake calipers from a 1970 Road Runner. $100
New set of original style 70/71 white air grabber hose to hood clips. $35
New disk brake dust shields for 70-72 B&E-bodies. Some surface rust from sitting on the shelf. $100
1970 Road Runner/Satellite grill and headlight bezels. Grill and driver side in nice shape. All four mounting tabs are intact on the grill and the Plymouth emblem is included. The passenger side headlight bezel has some minor damage on the outer edge outside of the chrome molding. Looks like it should be easily repairable or may not even be visible once installed. $200 for the set.
70 B-body column shift to trans. linkage. $120
Drum to drum 8 3/4 rear end from a 1970 440+6 Road Runner. Has 11" drum brake and a 4:10 center. Brakes should be rebuilt. $750 (no shipping)
1970 Plymouth B-body 4 pc. headlight bezel outer long screw set. $7
68-70 B-body vinyl top moldings. $75
Complete 70 B-body AM/FM radio system including both front and rear speakers, front to rear fader switch and wiring harness. Works great. Front speaker needs re-coning but rear speaker is excellent. $850
1970 Sport Satellite/Coronet non-rally dash woodgrain radio bezel. Nice condition. $75
Real nice 70 B-body horn relay/ignition buzzer #2986395. $50
68-70 B-body radiator to k-frame brace. $20
Nice A/B-body chrome console shift knob (knob only, no button). $20
Nice 70 RR/GTX gas filler door/rear license plate bracket. $40
1970 Satellite/Road Runner/GTX driver side rear bumper reverse light assembly. Very nice $50
Two frame strut rod shields. Both same side part #4434. $5 each.
Miscellaneous 1965 Satellite parts lot. Included are one blower switch and bezel (no knob), one wiper switch with bezel and knob, two door jamb dome light switches and two chrome knobs that I am not sure what they are for. $25 for the lot.
New chrome master cylinder cover. $8
A/B 68-70 black seat belt guides for where the seat belts go through the bench seat. $25
Full circle chrome horn ring for 1966 type three spoke steering wheels. Some light pitting. $40 I will also throw in a 2nd ring that has some nicks for no extra charge.
1968-69 style full circle chrome horn ring for three spoke steering wheels including horn cap. Some light pitting $45
New in the box Hurst ProMatic shifter. $225
Two 68 amber side marker lenses. $10 each
70 B-body rally dash with knob style radio woodgrain decal kit. $85
Seat belt retainer clips that mount on bottom of seats. 1 double clip and 3 singles in green $25.
Driver side deluxe chrome remote mirror. Pretty nice chrome but glass is loose. $60
70 B-body column shift power steering column. $200
2 NOS 68 side marker light lenses 1 amber, 1 red. $15 each
68-69 A/B-body black three spoke steering wheel. Pretty nice, no cracks just typical wear and one small blemish. Comes with original brushed finish partial horn ring. I also am including a chrome full circle horn ring with it for free (has some pitting). $180
1970 Woodgrain rally dash radio bezel cut for aftermarket radio. Save your uncut original and use this to install an aftermarket radio. $35
1968-9 B-body dash wire harness for non-rally gauges. $125
68-69 A/B-body chrome bucket seat headrest bezels. Some pits. $15 for set of 4.
New B-body quarter window roller kit less two rollers. $30
New 1970 B-body knob style woodgrain radio bezel decal. $18
Pair of 66-67 Charger parking light lenses SRE DP66. $30
New Grant Tuff steering wheel with horn cap. $80
1969 Road Runner dual snorkel air cleaner lid. $200
NOS 1968 Michigan license plates . $50
1970 GTX Muscle cars trading card #94 featuring a red GTX. $3
1970 Road Runner (purple) Road Warriors trading card. $3
Prices do not include shipping. Can email pics. Email: gt340 at yahoo.com
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2673060
07/02/19 02:24 PM
07/02/19 02:24 PM
NJ
moparply Offline
moparply  Offline
NJ
NOS 1970 Roadrunner GTX Air Grabber Air Scoop Decal, Passenger side, SOLD
NOS 1970 Roadrunner GTX Air Grabber Air Scoop Decal, drivers side, SOLD
Original 1970 Roadrunner GTX Air Grabber Air Scoop solenoid, needs repair to one of the nipples, works great, SOLD
NOS and Original 1970 Roadrunner Superbird GTX parts.
Email Kenei@comcast.net
Thanks Moparts!
70 charger hood latch [Re: moparts] #2673090
07/02/19 03:16 PM
07/02/19 03:16 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$40. the spring is NOT included with this
located 40 miles east of indy, shipping determined by your zip code
can bring the part to carlisle on saturday,
message me here or email at held1823@hotmail.com
jkjhgfty a.jpg (653 downloads)
jkjhgfty b.jpg (653 downloads)
70 charger side markers [Re: held1823] #2673093
07/02/19 03:17 PM
07/02/19 03:17 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$40 for the pair
jkjhgfty c.jpg (674 downloads)
jkjhgfty d.jpg (676 downloads)
70 charger front turn signals [Re: held1823] #2673095
07/02/19 03:20 PM
07/02/19 03:20 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$75 for the pair
jkjhgfty g.jpg (673 downloads)
jkjhgfty h.jpg (672 downloads)
jkjhgfty f.jpg (673 downloads)
jkjhgfty e.jpg (673 downloads)
70 charger front valance [Re: held1823] #2673098
07/02/19 03:22 PM
07/02/19 03:22 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$50
jkjhgfty k.jpg (652 downloads)
jkjhgfty l.jpg (656 downloads)
jkjhgfty i.jpg (653 downloads)
jkjhgfty j.jpg (654 downloads)
1968 B body radiator core support [Re: held1823] #2673100
07/02/19 03:25 PM
07/02/19 03:25 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$250
jkjhgfty m.jpg (650 downloads)
jkjhgfty n.jpg (648 downloads)
jkjhgfty o.jpg (645 downloads)
jkjhgfty p.jpg (648 downloads)
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2673102
07/02/19 03:26 PM
07/02/19 03:26 PM
mopar heaven
rustbucket Offline
rustbucket  Offline
mopar heaven
For sale:
1970 Road runner/satellite lower grill insert. Perfect original piece. No cracks or wattage. $50 440-864-7252
1970 383 Holley 4367 [Re: held1823] #2673103
07/02/19 03:27 PM
07/02/19 03:27 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Holley 4367 for 70 383 4spd . Very clean, all throttle blades open smoothly .$200.00 Can deliver to Carlisle.
Daytona Z-brackets [Re: held1823] #2673104
07/02/19 03:31 PM
07/02/19 03:31 PM
New Castle, Indiana
held1823 Offline
held1823  Offline
New Castle, Indiana
$300 for the pair. of well made set of nose cone z-brackets.
the brackets are the ONLY thing available in the photo
fitment is dead on, only detail not reproduced on them is the "popsicle stick" indentation
jkjhgfty q.jpg (635 downloads)
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: moparts] #2673106
07/02/19 03:32 PM
07/02/19 03:32 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
1967 Coronet R/T Grille Blank $445,
1967 Coronet R/T 150 MPH Speedometer Cluster Assembly $545,
1967 Coronet R/T Trunk Finish Panel With Emblem, Some Pitting $425,
67-69 Console Tachometer $495,
68-69 Big Block 11” Bellhousing $495,
#4617 1969 440 4-Speed Carter AVS Carburetor $295,
1969 And Early 1970 Factory Original Edelbrock Aluminum 440 6-Pack Intake Manifold $750,
Restored #3488577 1971 440 6-Pack Dual Point Distributor With NOS Vacuum Advance Unit $895,
Tonysparts.Com 302-398-0821, Harrington Delaware
tonysparts.com
302-398-0821,
Tonys Parts
Harrington Delaware 19952
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: TONY_DAGOSTINO] #2673118
07/02/19 03:34 PM
07/02/19 03:34 PM
DELAWARE
DELAWARE
New Reproduction Ashtrays And Bezels,
These Are An Exact Replacement Of The Original, So Now Is Your Chance To Replace The Rusty, Broken Or Missing Ashtray With A Brand New Shinny One.
They Fit 1971-74 E-body And B-body Consoles,
1970 E-body Rear Interior Panels And
66-70 B-body Armrests
Available For $45,
tonysparts.com
302-398-0821,
Tonys Parts
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: TONY_DAGOSTINO] #2673124
07/02/19 03:35 PM
07/02/19 03:35 PM
DELAWARE
DELAWARE
New Reproduction Console And Glovebox Door Locks,
These New Locks Work Smooth And Fit Just Like The Originals, Replace That Worn, Broken Or Missing Lock With A Nice New One.
They Fit:
64-74 B-body & 70-74 E-body Console Lids,
69-76 A-body Console Lids (must Remove Bezel),
62-69 B-body Glovebox Doors &
68-69 A-body Glovebox Doors.
Available For $40,
tonysparts.com
302-398-0821,
Tonys Parts
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: TONY_DAGOSTINO] #2673129
07/02/19 03:38 PM
07/02/19 03:38 PM
DELAWARE
DELAWARE
Dash Mounted 4-Speed Reverse Light
Used on 68-Newer 4-Speed Cars
$75 NEW LOWER PRICE!
302-398-0821
TONYSPARTS.COM
Tony’s Parts
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: TONY_DAGOSTINO] #2673132
07/02/19 03:38 PM
07/02/19 03:38 PM
DELAWARE
DELAWARE
67-70 B-body Console Body.
Injection Molded As Original.
Fit And Look Are Perfect.
Has All Factory Mounts, Holes And Locating Tabs.
Install Your Trim And Install In Your Car! $250.
(add $15 For 4-speed Version)
Available Through Tonys Parts
302-398-0821
tonysparts.com
Tony’s Parts
Re: 70 Back - B Body Parts For Sale - 3rd Quarter [Re: TONY_DAGOSTINO] #2673135
07/02/19 03:39 PM
07/02/19 03:39 PM
DELAWARE
DELAWARE
Clip Set For 68-69 A+B-Body Bucket Seat Hardback Panels.
Many Times The 68-69 A Or B Bodies (Charger, Coronet, Road Runner, GTX, Satellite, Barracuda And Dart) Are Either Missing Their Bucket Seat Hardback Panel With Clips Or They Are Beyond Repair.
While The Bare Hardback Panels Have Been Available, The Clip Set Hasn’t.
Since We Deal In A Lot Of Bucket Seats And Found That Many Were Missing The Backs We Saw A Need For The Clip Set. The Clip Set Makes The Hardback Panels Easy To Install To The Seats Just Like The Originals.
We Offer A 6 Piece Clip Set (4 Upper Clips And 2 Lower Edge Clips) To Complete A Seat Back Panel For 1 Seat. They Are Die Stamped And Have All Of The Same Bends As The Originals.
The Original Clips Were Secured To The Seat Back Panel From The Factory With An Industrial Strength Staple Gun, We Have Included An Easy To Use Rivet Set For Ease Of Installation. If You Need For Both Seats Then 2 Clip Sets Are Required.
Now In Stock For $25 per seat kit
Available Through
Tony’s Parts
302-398-0821
tonysparts.com
1970 Dodge Coronet Super Bee
by tomsjack. 09/21/19 04:17 AM
WORLD CUP - LIVE - rugby ....
by Doc Fiberglass. 09/21/19 12:49 AM
Mecum Louisville.....
by Doc Fiberglass. 09/21/19 12:16 AM
Stainnless valves for Indy heads
by theman440. 09/20/19 11:55 PM
Moparts Recent Posts
1971 Challenger Elastomeric Bumpers
by swisshemi. 09/21/19 04:33 AM
2 lane blacktop-rear discs!
by RamblerMan. 09/21/19 01:37 AM
by Doc Fiberglass. 09/21/19 01:25 AM
