Re: Ported 915 iron heads flow #'s- Whatcha think [Re: HardcoreB] #267298
06/09/10 11:00 AM
06/09/10 11:00 AM
Modesto, CA
Chris_Holton Offline
Modesto, CA
I am doing a set of 915's right now. I havent ported old school heads in 10 years, now I have two sets to do, I will post results in a few days....
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267299
06/09/10 02:43 PM
06/09/10 02:43 PM
I just got back a set of ported 915's that I bought used. I had them freshened up, while the shop had them they threw them on the bench. What do you think?
Numbers are at 28"
.100 IN 74.4 / EX 57.9
.200 IN 148.9/ EX 99.9
.300 IN 208.9/ EX 135.6
.400 IN 268.9/ EX 170.3
.500 IN 258.2/ EX 191.9
.600 IN 262.9/ EX 205.3
.700 IN 258.2/ EX 207
These heads going on zero deck, stock stroke 440 with MOPAR 590 solid cam, worked over M1 single plane intake, 850HP annular booster carb, and pro parts big tube headers. Any comments?
What kind of power would you feel this would make?
My comments, three things wrong, iron heads, Mopar 590 cam and annular boosters Is this a race only or dual duty motor and car? If it is a dual duty, be careful on the fuel, the iron close chamber heads will detonate very easily with the wrong fuel and tune up That being said I have used one of the older 590 cams one time , that motor had "346" heads and is still running in a bracket car after six or seven yaers of being race 5 to 15 times each year on race fuel good luck BTW, I saw the same results on that bracket motor on the engine dyno testing a Carb shop custom 1050 Dominator with a tapered dominator adapter against a BG 850 Street Demon on a TM7 intake, we later switch the intake to a 4500 Team G intake and a stock Holley 9375 1050 Dominator and saw a 30 HP increase with the Team G intake and no adapter
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: Cab_Burge] #267300
06/09/10 06:03 PM
06/09/10 06:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Whats the problem with annular booster
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: ademon] #267301
06/10/10 12:58 AM
06/10/10 12:58 AM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
Cab- this is for a bracket drag car. It will see little if any street duty. I wanted to see what an old school "state of the art circa 1978" build could do. I consider myself a Mopar "purist" Good bad or indifferent, that was the thought process.......LOL
Curator at Adams County Speed Shop
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267302
06/10/10 01:09 AM
06/10/10 01:09 AM
iowa
rook440 Offline
rook440  Offline
iowa
pretty good numbers .....cant wait to see it in the dart .....what year did you start building that engine ???? Do you like flat tappet cams ....??? this build and the day at the dyno really got me enthused ..... I still owe you one ,,,,,rook
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: rook440] #267303
06/10/10 01:18 AM
06/10/10 01:18 AM
Creston, Iowa
3
Creston, Iowa
I started the engine build in 1978 LOL........
Flat tappet cams and iron heads will rise again....I can feel it.............
Thanks for your help, support and friendship Rook
Mr Looney
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267304
06/10/10 01:20 AM
06/10/10 01:20 AM
Creston, Iowa
3
Creston, Iowa
If you owe me one......I owe you many...........
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: 340man4ever] #267305
06/10/10 08:27 AM
06/10/10 08:27 AM
Lehigh Acres, Florida
rickstershemi Offline
Yep, I'm excited to get going on our 318/390 Stroker Max Ported J-Heads, 11-1 Compression Tunnel Ram, Extremely Radical Hydraulic Flat Tappet Cam, 4-Speed
Rickster
Re: Ported 915 iron heads flow #'s- Whatcha think [Re: rickstershemi] #267306
06/10/10 10:52 AM
06/10/10 10:52 AM
Creston, Iowa
3
Creston, Iowa
Rickster
That sounds like a fun build up......
Very cool
