W9-RP Head Studs? P5007912
#2672924
07/02/19 10:03 AM
07/02/19 10:03 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
I need to know what the specs are for the $1200 Mopar Head stud kit. Part Number P5007912
Most places are running out of stock so they are getting hard to find.
That said, I talked to ARP a few months back and they said they had nothing in their listings for the W9-RP. BUT if I had the specs they could get something together for me.
I know they are 1/2" dia. in the block and 7/16" dia. through the head. There are 3 different lengths. 2 sets are 10 pieces and 1 set is 16 pieces. 12-point nuts.
If I can get the lengths I think they could figure out the rest and put together an affordable set.
If someone knows all the details that would be awesome.
I used to have a set but "Storage Thieves" wanted them I guess!
Re: W9-RP Head Studs? P5007912
[Re: usp4u]
#2672966
07/02/19 11:06 AM
07/02/19 11:06 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
There’s a place called Allens Fasteners on the net. They carry individual arp studs. I realize what you need are the actual dimensions, but you can come up with that by measuring the head/ block.
[Re: usp4u]
#2673000
07/02/19 12:41 PM
07/02/19 12:41 PM
Posts: 3,496 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Not sure I the RP studs are different, but Kent Ritter put me together my sets of 'stepped' W9 studs. Was much more affordable than tracking down pre-packaged kits. Curious as to why regular W9 heads would need "stepped" studs. The ones I use with my W9 heads are not stepped. Thanks!
[Re: 340Cuda]
#2673016
07/02/19 12:58 PM
07/02/19 12:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not sure I the RP studs are different, but Kent Ritter put me together my sets of 'stepped' W9 studs. Was much more affordable than tracking down pre-packaged kits. Curious as to why regular W9 heads would need "stepped" studs. The ones I use with my W9 heads are not stepped. Thanks! My W-9 stuts werent stepped down.. sorry to to the OP but I dont recall the lengths
[Re: DakFink]
#2673018
07/02/19 01:03 PM
07/02/19 01:03 PM
340Cuda
Tulsa, Oklahoma
I need to know what the specs are for the $1200 Mopar Head stud kit. Part Number P5007912 You might contact member 69 lawndart. He has/had and engine with W9 RP heads.
[Re: 340Cuda]
#2673035
07/02/19 01:42 PM
07/02/19 01:42 PM
TRENDZ
Milwaukee WI
Here is a cutaway of a rp head. The entire row of bolts between the ports are 7/16. The heads are much taller than a standard w9 also.
