5.7 ring gap w/ nitrous #2672809
07/01/19 10:52 PM
07/01/19 10:52 PM
New Braunfels, TX
416challenger Offline OP
New Braunfels, TX
I have a low mileage 2018 5.7 hemi that I picked up recently. I have it apart to check the bearings and do a cam swap. While I have it apart I want to open up the ring gaps encase I spray the motor. How much are you guys opening up the ring gaps on stock bottom ends for nitrous?
Re: 5.7 ring gap w/ nitrous [Re: 416challenger] #2672845
07/02/19 05:18 AM
07/02/19 05:18 AM
Texas
0
03heavy Offline
03heavy  Offline
Texas
I would probably just use the mmx drop in piston
Instructions as a guideline there is a video on you tube
Bore size x 7 I believe but you should check before relying on my memory
Could you post a close picture of the top rind land of
A picture I would like to compare it to a car srt
Re: 5.7 ring gap w/ nitrous [Re: 03heavy] #2672875
07/02/19 08:07 AM
07/02/19 08:07 AM
New Braunfels, TX
New Braunfels, TX
I'm not going to change pistons at this time. When I do I will replace the rotating assembly.
Re: 5.7 ring gap w/ nitrous [Re: 416challenger] #2674738
07/06/19 10:23 AM
07/06/19 10:23 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
.018-.02 is where I would gap it.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
