Fuel tank sending units #2671075
06/28/19 11:18 AM
06/28/19 11:18 AM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
I need a new 3/8 sending unit for my 70 Cuda. Has there been any improvements in the last few years in these? I have bought a few for other Mopars thru the years and the accuracy was pretty dismal. Any particular brand or vendor you can recommend?
Re: Fuel tank sending units [Re: Lee446] #2671142
06/28/19 01:43 PM
06/28/19 01:43 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Nope they all suck
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Fuel tank sending units [Re: HemiRick] #2671163
06/28/19 02:25 PM
06/28/19 02:25 PM
there was a prior thread (or two) on where a good one might be obtained (agreed they are the worst of the worst & definitely do your homework).
Re: Fuel tank sending units [Re: RapidRobert] #2671398
06/29/19 06:00 AM
06/29/19 06:00 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
not too long ago someone posted a reply with a link to a company that will rebuild them to be accurate.ill see if i can find the link. sendingunitguy@gmail.com (315-712-0071). i havnt talked to them yet but im gunna.
Re: Fuel tank sending units [Re: Lee446] #2672105
06/30/19 08:49 PM
06/30/19 08:49 PM
robertop Offline
robertop  Offline
I just bought a repro for my 69 Hemi bird from Year One, and the guy told me they did not get any complaints......so, we'll see in a week or two.
Re: Fuel tank sending units [Re: robertop] #2672432
07/01/19 10:45 AM
07/01/19 10:45 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I got my new tank and sending unit from a reputable source and I think I can say it will never leave me stranded because I can't make it home after hitting Empty. On my 18 gallon tank, it leaves me with a nine gallon safety margin. Better than the alternative I guess.
Re: Fuel tank sending units [Re: gzig5] #2672493
07/01/19 12:03 PM
07/01/19 12:03 PM
Agreed, if there's a choice I'd ideally like to have a few gallons left when the needle hits E
Re: Fuel tank sending units [Re: RapidRobert] #2672515
07/01/19 12:32 PM
07/01/19 12:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Reminds me of my riding days, run till you go empty, flip on the reserve and look for a station.
That worked ok till I forgot to flip back. Then I bought a new EFI bike with no reserve so that idea was out the window.
Re: Fuel tank sending units [Re: Sniper] #2672523
07/01/19 12:44 PM
07/01/19 12:44 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Did the same thing. haha
I didn't know the newer efi bikes lacked a reserve. Too bad.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Fuel tank sending units [Re: DynoDave] #2672708
07/01/19 07:45 PM
07/01/19 07:45 PM
Maryland
MoparMike1974 Offline
Maryland
I just finished installing a meter match in my dart. It allows you to program set points to make the sending unit accurate. It will be a while before I get a chance to use it but in theory it looks like it should work great. It has several calibration points to compensate for odd shaped tanks.
https://www.technoversions.com/MeterMatchHome.html
A bonus is that the unit will provide the voltage to your gauge so the old limiter can be removed. Although you still need to power the temp gauge with a different source. The meter match instructions say it will only handle one gauge. I installed a 7805 regulator, and heatsink to power my temp gauge.
