Re: Hilborn EFI 512 Charger
[Re: CSK]
#2672015
06/30/19 05:37 PM
06/30/19 05:37 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looking forward to hearing how this all works out.
Do you have a sacrificial hood yet?
Does AMD offer one for that?
[Re: fast68plymouth]
#2672020
06/30/19 05:50 PM
06/30/19 05:50 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Does AMD offer one for that? I might cut the glass cowl hood that is on the car, I have a steel cowl hood that I made & it is a short cowl type, but it is very HEAVY, probably will run without a hood at 1st till I get it all working good then make a decision, a glass flat hood would be my best choice. this is the one I made, it was not tall enough for my air filter so I got the glass one about 4 years ago.
[Re: CSK]
#2672024
06/30/19 05:57 PM
06/30/19 05:57 PM
fast68plymouth
So. Burlington, Vt.
What’s the air filter situation with the stacks?
#2672030
06/30/19 06:08 PM
06/30/19 06:08 PM
CSK
Pattison Texas
Speedway had some on sale they are K&N & I dont like them , but they are not to bad if you use an Outerwear over them to keep the fine dust out,
[Re: CSK]
#2672636
07/01/19 05:13 PM
07/01/19 05:13 PM
CSK
Pattison Texas
The mock up, this is going to take a lot of finesse just to bolt this up,raised port heads would be much better, but I will figure it out.
[Re: hemi-itis]
#2672759
07/01/19 09:13 PM
07/01/19 09:13 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Really dig that set up!! Wish I could have EFI This would look right at home on your blower Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#2672859
07/02/19 07:22 AM
07/02/19 07:22 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I think it'd be cool if you just put short stacks on it and left it all under the hood. The wow factor would double when you popped the hood. And so would the inlet air temps.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2672916
07/02/19 09:41 AM
07/02/19 09:41 AM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
And so would the inlet air temps. like almost every other car out there !! Besides, an efi adjusts for all that.
[Re: fourgearsavoy]
#2672945
07/02/19 10:35 AM
07/02/19 10:35 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Really dig that set up!! Wish I could have EFI This would look right at home on your blower Gus EFI for my heap would be in the $5k range
[Re: Stanton]
#2672968
07/02/19 11:09 AM
07/02/19 11:09 AM
Bad340fish
Tulsa OK
And so would the inlet air temps. like almost every other car out there !! Besides, an efi adjusts for all that. That it does, but it still reduces air density and therefore power.
[Re: Bad340fish]
#2673993
07/04/19 12:52 PM
07/04/19 12:52 PM
CSK
Pattison Texas
I had to think this one out, the throttle cable & transmission throttle pressure control cable, air filters, the ram tubes will be silver when done., will paint my brackets black.
[Re: Bad340fish]
#2674031
07/04/19 01:53 PM
07/04/19 01:53 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
And so would the inlet air temps. like almost every other car out there !! Besides, an efi adjusts for all that. That it does, but it still reduces air density and therefore power. The car has a/c, I doubt the small loss of power would be a concern. Personal experience tells me to keep everything under the hood and out of plain sight. Nothing attracts destructive morons than stuff peeking out of the hood. You never know when you're going to have to park it somewhere unattended for a while !!
[Re: moparx]
#2674050
07/04/19 02:26 PM
07/04/19 02:26 PM
Posts: 4,457 Washington
madscientist
Washington
IDK...I kinda like the gold stacks. Adds a little bling to it.
