manual steering boxes #267151
03/26/09 10:19 AM
03/26/09 10:19 AM
Muncie
Racebuddy Offline OP
Muncie
are manual steering boxes all the same?
A body put in B body...etc?
I got a aluminum box out of an A body put into a 67 Satellite and the steering column comes up a couple of inches short. The swap meet purchased column is out of a 66 B Body.
can someone enlighten me please?
Re: manual steering boxes [Re: Racebuddy] #267152
03/26/09 10:24 AM
03/26/09 10:24 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If you're car had power steering you'll need an adapter to go to manual.
Re: manual steering boxes [Re: justinp61] #267153
03/26/09 10:35 AM
03/26/09 10:35 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Or a manual steering column shaft.
Re: manual steering boxes [Re: Cuda_Mike] #267154
03/26/09 10:43 AM
03/26/09 10:43 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Power and manual steering shafts are different lengths.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: manual steering boxes [Re: Racebuddy] #267155
03/26/09 12:57 PM
03/26/09 12:57 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
If you pull the box apart you can look for either a bushing or the more heavy duty needle bearings.
I'm not sure what the cutoff was at the factory as to where the car got the bearings.
Based on what i have seen over the years, I would say a big block got that box and small and slant 6ers got the bushing box.
I want my fair share
Re: manual steering boxes [Re: SomeCarGuy] #267156
03/26/09 05:40 PM
03/26/09 05:40 PM
N.E. Ohio
mike69rr Offline
mike69rr  Offline
N.E. Ohio
good box, or with bearings is PN 2537349
Re: manual steering boxes [Re: justinp61] #267157
03/28/09 10:09 AM
03/28/09 10:09 AM
Muncie
Muncie
manual box with a automatic power steering column needs an adapter? OK.
Mancini has it for $130
any better deals out there for an adapter???
Re: manual steering boxes [Re: Racebuddy] #267158
03/28/09 01:27 PM
03/28/09 01:27 PM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
I have seen 2 of the universal joints that are on the end of the column put together. It had a piece of round metal stock on the inside with a hole drilled all the way through the joint with a pin in it, then the 2 joints were welded together. Has been on my friends car for 5 years now, still working fine. Also he did not have to cut the steering shaft, the extra coupler takes up just the right amount of slack. Hope this helps.
Re: manual steering boxes [Re: Racebuddy] #267159
03/28/09 07:08 PM
03/28/09 07:08 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
If you have a colapsable (sorry spelling) steering column you can extend the shaft from the plastic clips. When you get it the right length, weld the shaft solid through the cage for the column.
6.50 @105.26
