Weiand Stealth 8022 #2669444
06/24/19 03:18 PM
06/24/19 03:18 PM
ontario canada kingston
aspenrt360 Offline OP
Hey there guy's anyone using a weiand stealth 8022 manifold? i want to know how it compares to an Eddy air gap. i am pretty sure the eddy is better i have a couple on two of my cars now but i have a shot at the weiand for a pretty good price. going on a street 360 with a comp 480 magnum cam and some ported j heads in a b body with a 3000 rpm stall converter and 3.23 gears.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Weiand Stealth 8022 [Re: aspenrt360] #2669511
06/24/19 06:46 PM
06/24/19 06:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They're not a bad intake, never done a back to back against an Air Gap though. A 2" open spacer would liven it up as well
Alan Jones
Re: Weiand Stealth 8022 [Re: LA360] #2669965
06/25/19 08:34 PM
06/25/19 08:34 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I actually have done a back to back. Felt no real difference going from the air gap to the stealth, but didn't want to swap back so the stealth has been on ever since.
Only two beefs I do have with the stealth 1) no provision to mount coil like stock and most other aftermarket intakes 2) every single port was a different size, so plan on gasket matching.
Still its a good intake, probably the best readily available dual plane IMHO (Its pretty much identical to the coveted LD4B intake) if you need the heat crossover for cooler climate driving or fast warm up.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Weiand Stealth 8022 [Re: aspenrt360] #2670055
06/26/19 05:48 AM
06/26/19 05:48 AM
Locomotion Offline
Locomotion  Offline
I compared it to a Holley Strip Dominator and it was a bit slower. But due to the higher limits of the combo (converter, gear, cam duration, etc.), I wasn't surprised.
If you do some tuning with the Stealth, try 2 #s difference between the left & right sides. The deeper side plenum liked to be 2 numbers richer than the shallower side. (...or 2 #s leaner in the shallow plenum, depending how close you are to optimum to start with.) This was with a 1" tapered 4-hole Canton phenolic spacer & Holley 750DP. Car ran several hundredths faster and plug color was more consistent. A-B-A-B testing same day.
Re: Weiand Stealth 8022 [Re: Michael Ecks] #2670531
06/27/19 03:25 AM
06/27/19 03:25 AM
LA360 Offline
LA360  Offline
A seat of the pants test isn't going to tell you much, but worth hearing nonetheless
Alan Jones
2011 4x4 problem
by HotRodDave. 01/24/20 10:08 PM
BS27N0B297503 - for sale with re-stamped block
by Alaskan_TA. 01/24/20 08:01 PM
110 vs 93 octane
by Transman. 01/24/20 07:15 PM
'68 340 S Barracuda
by oldjonny. 01/24/20 06:43 PM
Moparts Recent Posts
Racing today
by tex013. 01/25/20 02:56 AM
'68 340 S Barracuda
by Jjs72D. 01/25/20 02:54 AM
