Hemi block identification #2670432
06/26/19 08:57 PM
06/26/19 08:57 PM
NW Illinois
MoonshineMattK Offline OP
NW Illinois
Anyone know what this is
Re: Hemi block identification [Re: MoonshineMattK] #2670488
06/26/19 10:58 PM
06/26/19 10:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Looks like a polished KB
Not completed
2011 Drag Pak Challenger
Re: Hemi block identification [Re: rickseeman] #2670514
06/27/19 01:26 AM
06/27/19 01:26 AM
NW Illinois
NW Illinois
Thanks.
Its listed as a billet block. Do you have any idea what vintage this would be? Looks like one cross bolt per side instead of two. Also MOPAR and HEMI are engraved into the skirt rather than cast in
Re: Hemi block identification [Re: MoonshineMattK] #2670535
06/27/19 06:58 AM
06/27/19 06:58 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
It looks to be a cast kb. Maybe someone ran it through a lightening program?
Not a billet block with core plugs.
Re: Hemi block identification [Re: MoonshineMattK] #2670550
06/27/19 08:03 AM
06/27/19 08:03 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by MoonshineMattK
Thanks.
Hmmm....that almost looks to me like something that might have happened on my former management's watch, maybe as a licensing thing.
Marketing pushed 'mopar hemi' branding really hard from '05 to about '11, I don't know what was spent on stickers and T shirts but it was a whole lot.
(You'll also notice "mopar wedge" branding on a few parts from then (certain heads and intakes) to try to make sure nobody felt left out.)
I'll ask a few of the guys from back then and see if anyone can remember this.
(MP did have a KB block supercharged crate engine for a short time, maybe it is from that program).
Rich H.
Esse Quam Videri
Re: Hemi block identification [Re: ZIPPY] #2670561
06/27/19 09:11 AM
06/27/19 09:11 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
KB offered polish as an option.
Re: Hemi block identification [Re: rickseeman] #2670601
06/27/19 10:36 AM
06/27/19 10:36 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
It's strange. If you look at the first set of pics, specifically the one of the timing cover area there are no upper water holes. Yet it has core plugs. So its either it's a solid block or it's a water block without the holes drilled. The block number should be stamped by the oil pump mount or on the pan rail. KB will have the info on what year and what it is.
Re: Hemi block identification [Re: fbs63] #2670604
06/27/19 10:45 AM
06/27/19 10:45 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It used to be that way.
Re: Hemi block identification [Re: fbs63] #2670655
06/27/19 12:59 PM
06/27/19 12:59 PM
NW Illinois
NW Illinois
I noticed the water pump holes also. Not in the market for a solid block.
