ATI damper for RB with Indy timing cover #2668836
06/22/19 09:24 PM
06/22/19 09:24 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
Anybody positive which ATI super damper i would need with the Indy cast timing cover with crank hub spacer? I thought it was the same one as for the jesel belt drive setup, but i want to make sure before i pull the trigger. Figured i’d check here with the experts first instead of calling and possibly waiting on hold.
Re: ATI damper for RB with Indy timing cover [Re: Chargerfan68] #2668838
06/22/19 09:45 PM
06/22/19 09:45 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
ATI #917127E damper is the one I have.
Re: ATI damper for RB with Indy timing cover [Re: cudatom] #2668879
06/22/19 11:28 PM
06/22/19 11:28 PM
New York, USA
New York, USA
Thanks for the info up
Re: ATI damper for RB with Indy timing cover [Re: Chargerfan68] #2669161
06/23/19 09:58 PM
06/23/19 09:58 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
They have a chart on their website with the info you need.
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car (project)
2006 Ram 1500 SLT 4x4
Re: ATI damper for RB with Indy timing cover [Re: 69Mcode440] #2669181
06/23/19 10:35 PM
06/23/19 10:35 PM
New York, USA
New York, USA
Mike
Yes, thanks. I did find that chart, but like in the past, i have purchased parts from company websites, and they did not fit right, or were incorrectly listed. I figured its best to ask the real deal racers here that built this combo. Thanks for pointing that out though. up
Re: ATI damper for RB with Indy timing cover [Re: Chargerfan68] #2669183
06/23/19 10:43 PM
06/23/19 10:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had to put a small shim that ATI offers behind my ATI damper with my Indy cover.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ATI damper for RB with Indy timing cover [Re: pittsburghracer] #2669484
06/24/19 06:29 PM
06/24/19 06:29 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
This ^^^^. Without the extra shim the damper will 'bottom'out' on the timing cover.
Re: ATI damper for RB with Indy timing cover [Re: Dduster] #2669578
06/24/19 10:16 PM
06/24/19 10:16 PM
New York, USA
New York, USA
Thanks so much guys. I will make sure i check clearance and use one. Great information that helps in case i missed that. up
Re: ATI damper for RB with Indy timing cover [Re: Chargerfan68] #2669615
06/24/19 11:31 PM
06/24/19 11:31 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
I bought the hub listed for use with the indy cover and just swapped it with the original hub on my ATI damper. Summit has them in stock.
Mike
Mike
69 440 Cuda
71 Dart drag car
WIW - I'm Bored already - '66 Wagon
by oldjonny. 07/17/19 01:46 PM
computer reaction to engine mechanical problems
by volaredon. 07/17/19 01:34 PM
phanton push button start system
by 70moparmike. 07/17/19 12:59 PM
Who's Central A/C knowledgeable?
by MONC. 07/17/19 12:35 PM
Epoxy/metal filler that will hold up in exhaust port?
by Michael Ecks. 07/17/19 10:44 AM
work/life balance
by feets. 07/17/19 08:14 AM
Moparts Recent Posts
'Myth' of Mopar lifter diameter advantage?
by BSB67. 07/17/19 02:35 PM
by not_a_charger. 07/17/19 02:30 PM
What timing are you running on your 512?
by MR_P_BODY. 07/17/19 02:29 PM
by Tom_440. 07/17/19 02:24 PM
How Chrysler helped put a man on the moon
by YGBSM. 07/17/19 01:54 PM
