Re: dead dakota.........still
[Re: rhad]
#2678131
07/16/19 11:21 PM
07/16/19 11:21 PM
Posts: 954 garnett kansas
rhad
garnett kansas
new cap rotor wires can sensor,it still died!!,new fuel pressure checker,35# up to 40 when you rev it up then i noticed that the drain for the ac was dripping right on part of the crank sensor plug!!! WHOOOO!!,tomorrows project.....inspect and move those wires!!,ran for a hour in the shop,no problem?????????
my ladder of success is missing some rungs
[Re: rhad]
#2678222
07/17/19 09:41 AM
07/17/19 09:41 AM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
Still following along. Good luck with it. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2678490
07/17/19 11:30 PM
07/17/19 11:30 PM
rhad
garnett kansas
looked at and moved the crank sensor wires and plug,no corrosion detected,hasnt died in the last 2 runs??????? whats left to do????fuel filter is old,but no signs of restriction,revs good pressure stays good ethanol should take care of water in the gas,if any???,as ive said before,it might run good for a couple days then die,then restart
[Re: rhad]
#2680661
07/23/19 08:04 PM
07/23/19 08:04 PM
Posts: 1,680 Raleighwood
2Bad360sfromNC
Raleighwood
My '91 had a bout of random death a couple years ago. No sputtering--it was just like you turned off the key. After trying most everything mentioned above, I changed the hall effect pickup in the distributor, and that fixed it. I now ride with a spare in the glovebox.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D) 1974 Challenger 360 2012 Challenger R/T 1991 Dakota 5.2
[Re: 2Bad360sfromNC]
#2680737
07/23/19 11:23 PM
07/23/19 11:23 PM
rhad
garnett kansas
i have changed the hall effect in the dist,it still died on me!,new fuel filter on the way!
[Re: rhad]
#2681447
07/25/19 11:39 PM
07/25/19 11:39 PM
rhad
garnett kansas
new filter this evening,test drive tomorrow!!,keep your fingers crossed!
[Re: stumpy]
#2681710
07/26/19 10:52 PM
07/26/19 10:52 PM
rhad
garnett kansas
went for a morning cruise,did not die,no idea if its fixed or just being nice for a bit??,oh yeah,the speedometer didnt work,must of done something when replacing the filter,i need to drive for a few days to be sure,the 27 yr old rubber fuel lines were mushy(my problem??),so i shortened one quite a bit and cut a lot off of the other one and spliced in a longer piece to make it reach the filter
[Re: rhad]
#2681721
07/27/19 12:28 AM
07/27/19 12:28 AM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
Mushy? I wonder if the ethanol gas is attacking the lines? 27yr old lines should be hard and cracked, not mushy. Might want to go thru and replace anywhere that has old rubber line. Make sure the new line is ethanol resistant.
John
[Re: SattyNoCar]
#2681802
07/27/19 12:58 PM
07/27/19 12:58 PM
rhad
garnett kansas
the fuel injection lines have a liner so im ok there,HOWEVER,it ran about 150 feet this morning and died,im gonna fix up a fuel pressure gauge so i can moniter it while driving,if its NOT the fuel pump im stumped big time!!!
[Re: rhad]
#2682113
07/28/19 07:41 PM
07/28/19 07:41 PM
rhad
garnett kansas
hooked up the fuel pressure gauge,drove about 20 miles or so over various roads,no die,pressure steady at mid 30's still stumped!! gonna leave the gauge hooked up till it dies,as the saying went when i worked at the rabies lab,a negative test is never positive!!!!!!
[Re: rhad]
#2683142
07/31/19 03:58 PM
07/31/19 03:58 PM
I_bleed_MOPAR
Buford, GA
Tim
[Re: I_bleed_MOPAR]
#2683282
07/31/19 11:10 PM
07/31/19 11:10 PM
rhad
garnett kansas
gave it a break today,more to come
[Re: 360view]
#2684202
08/03/19 11:35 PM
08/03/19 11:35 PM
rhad
garnett kansas
the pump is a carter it has a round filter on the bottom much like a small air filter,fuel pressure has remained steady since i put the gauge on it,i think i have a bad connection somewhere,or a intermittent short?,if it would die and not restart i could find it!!! keep the hints/help coming please!!
[Re: jerseybud]
#2684492
08/04/19 11:05 PM
08/04/19 11:05 PM
rhad
garnett kansas
thanks!,the crank sensor was the first thing i replaced(with a mopar part!)
[Re: 360view]
#2689595
08/19/19 11:13 PM
08/19/19 11:13 PM
rhad
garnett kansas
i re soldered the 3 wire connection under the under hood fuse box just to be sure,also replaced the heater fan motor after all these years,started it up turned on the ac ,went to move another truck out of the way and it died and would not restart,very discouraged!!,gonna check in the morning! will a snap on 2500 show a history when it fails and then restarts?,its obd1
