Brad Penn Oil #2669313
06/24/19 10:06 AM
06/24/19 10:06 AM
Ont, Canada
gygeneral Offline OP
Ont, Canada
Anyone in Ontario, can you tell me where I can get my hands on this oil. I'm in the Niagara Area.
The Valvoline VR1 seems to be available in a lot of places, anyone using this
Re: Brad Penn Oil [Re: gygeneral] #2669396
06/24/19 01:25 PM
06/24/19 01:25 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, vr1 10w-30 in all my cars. only 1 car has vr1 20w-50. ronnie
Re: Brad Penn Oil [Re: gygeneral] #2669404
06/24/19 01:42 PM
06/24/19 01:42 PM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
I've used both, I was not impressed with Brad Penn, it seemed too thick and "stringy" and I suspected the viscosity rating was not accurate.
My 408 stroker had higher oil consumption using it, (albeit minor but I still noticed it).
Used VR-1 in both my stock 440 and 408 stroker with no issues for years, (both flat tappet)
twocents
Re: Brad Penn Oil [Re: Charger727] #2669423
06/24/19 02:35 PM
06/24/19 02:35 PM
...in Florida on a permanent S...
Doc Fiberglass Online content
Doc Fiberglass  Online Content
STRINGY oil ? .... reminds me of straight weight oil in the 40 to 60 weight range eek
Re: Brad Penn Oil [Re: Charger727] #2669436
06/24/19 03:07 PM
06/24/19 03:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
twocents
LMAO. Some of you guys are hilarious. I'm going to drain some of my 10-30 Penn Grade (Brad Penn) from my race car and see if my cats want to play with the string. LOL.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Brad Penn Oil [Re: pittsburghracer] #2669451
06/24/19 03:37 PM
06/24/19 03:37 PM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
twocents
Happy to be of service to you and your cats
Re: Brad Penn Oil [Re: Charger727] #2669472
06/24/19 04:33 PM
06/24/19 04:33 PM
Central,PA
62maxwgn Offline
62maxwgn  Offline
Central,PA
Ran Kendall GT 1 from back in the early 60's,when Brad Penn took over kept right on using and always will as long as they are around. twocents
Re: Brad Penn Oil [Re: gygeneral] #2669507
06/24/19 06:32 PM
06/24/19 06:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I found where it is available through WalMart.ca, probably not in the store but you can most likely order online and shipped free for store pickup?
https://www.walmart.ca/search/brad%20penn%20oil/N-114
Also there's an auto parts store or two in Mississauga ON that has it, don't know if it's called STC Auto parts or another Last Chance Auto parts??
Mike
Re: Brad Penn Oil [Re: 1969ronnie] #2669517
06/24/19 07:02 PM
06/24/19 07:02 PM
Connecticut
CrAlt Offline
CrAlt  Offline
Connecticut
I like VR1 for the simple fact that they actually publish their specs.
https://www.valvoline.com/our-products/motor-oil/vr1-racing-oil
It says they sell it in Canada. Comes in strait weights and 10w30, 20w50. Good zinc for my flat tappet stuff.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Brad Penn Oil [Re: CrAlt] #2669523
06/24/19 07:20 PM
06/24/19 07:20 PM
Ont, Canada
Ont, Canada
Yes I see that one in many stores, that's why I asked, seems to be more available
Re: Brad Penn Oil [Re: A12] #2669524
06/24/19 07:22 PM
06/24/19 07:22 PM
Ont, Canada
Ont, Canada
Mike
I also found it on Amazon.ca through a third party, was hoping to just go pick some up that's why I asked anyone who lives around here. Another option is to go over the the USA to pick some up, I live about half hour from the border but the summer is hell with tourists trying to get across without long lineups
Re: Brad Penn Oil [Re: gygeneral] #2669538
06/24/19 08:09 PM
06/24/19 08:09 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Try calling a local performance engine builder's shop, they may stock it or know where to get it locally That's were I got the last case of Brad Penn from.
Re: Brad Penn Oil [Re: CrAlt] #2669547
06/24/19 08:28 PM
06/24/19 08:28 PM
Central,PA
62maxwgn Offline
62maxwgn  Offline
Central,PA
Had Brad Penn tested years ago.
Re: Brad Penn Oil [Re: CrAlt] #2669548
06/24/19 08:28 PM
06/24/19 08:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Brad Penn Oil [Re: 62maxwgn] #2669552
06/24/19 08:31 PM
06/24/19 08:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill what were the results, as you know I'm not smart enough to read that report wink
Re: Brad Penn Oil [Re: A12] #2669583
06/24/19 09:29 PM
06/24/19 09:29 PM
PA.
"Little"John
"Little"John
PA.
Did you find any strings while testing the Brad Penn. Asking for a Friend
1970 Duster
6.143@110.85 mph
5.982@112.56 mph
9.42@138.27
Re: Brad Penn Oil [Re: pittsburghracer] #2669685
06/25/19 07:38 AM
06/25/19 07:38 AM
Indiana
Bc65851 Offline
Bc65851  Offline
Indiana
You can contact PennGrade / DA Lubricant directly.
https://penngrade.com/contact/ or 1-800-645-5823
They have distributors all over the US and Canada than can fulfill your request.
Re: Brad Penn Oil [Re: A12] #2669713
06/25/19 08:55 AM
06/25/19 08:55 AM
Central,PA
62maxwgn Offline
62maxwgn  Offline
Central,PA
Mike,zinc content which everybody was.is concerned was significantly reduced years ago. Shell Rotella was one of the choice oils in it's day but it went down same as most others.The zinc content is measured in ppm (parts pr million),when I had Brad Penn done it was 1577 ppm,think it still is,there may be other brands that are close but I doubt not many.Look at the far right of the analysis I posted and you can see the numbers.
Re: Brad Penn Oil [Re: 62maxwgn] #2669835
06/25/19 02:53 PM
06/25/19 02:53 PM
Connecticut
CrAlt Offline
CrAlt  Offline
Connecticut
Looked around and found their datasheet.
https://penngrade.com/files/7126-7150-7144-7158-7419_PG1_MultiGrade_HP_Oils.pdf
If it wasn't 10bux a qrt I would run it scope
Re: Brad Penn Oil [Re: CrAlt] #2669840
06/25/19 03:32 PM
06/25/19 03:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Is this the same D-A company that produced D-A Diesel Oil back in the day. I used the D-A Diesel Oil in my racing dirt bike transmission, Triumph Daytona 500 motorcycle and in my '69 Road Runner, great stuff up
(Also used the Speed Sport )
Mike
Taller Spindles- but small caliper brackets
by hulmule. 02/19/20 11:30 AM
FEB 22 - Winter Classic Swap Meet. Who's going?
by sixpackjeff. 02/19/20 11:28 AM
What oil to use
by dragon. 02/19/20 10:53 AM
67 R/T Needs a bit of work
by 65pacecar. 02/19/20 10:09 AM
Moparts Recent Posts
8 3/4 to a Dana
by polyspheric. 02/19/20 12:10 PM
64 Valiant - $4,000
by Doc Fiberglass. 02/19/20 12:08 PM
What oil to use
by polyspheric. 02/19/20 12:07 PM
by moparx. 02/19/20 11:57 AM
