regrind MP solid cam, Ok or not OK
#2669163
06/23/19 10:09 PM
06/23/19 10:09 PM
RapidRobert
I have one that is way too big for my app. Is it feasible (price/function) to have it reground & who should I sent it to? Thank you for your time. P4529973
Re: regrind MP solid cam, Ok or not OK
[Re: RapidRobert]
#2669193
06/23/19 11:10 PM
06/23/19 11:10 PM
Posts: 4,457 Washington
madscientist
Washington
I think Jim at Racer Brown will regrind a good core. You are limited as to how far you can change things though. I'm sure he can tell you how far he can change things before you run into issues.
[Re: RapidRobert]
#2669201
06/23/19 11:31 PM
06/23/19 11:31 PM
Posts: 1,289 Tucson AZ,
MadMopars
Tucson AZ,
If you need a second opinion, give Schneider Racing Cams a call also. They're reasonably priced and seem to do nice work. -Trent Schneider Racing Cams 1235 Cushman Avenue San Diego, CA. 92110 Phone: (619) 297-0227 Fax: (619) 297-0577
[Re: RapidRobert]
#2669229
06/24/19 05:17 AM
06/24/19 05:17 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Unlikely that you would be able to go smaller. Cam lobe apex is usually ground into the cam at the max allowable size for the cam journal. “Bigger” cams usually have lobe apex heights similar to a small cam. It’s the base circle that is removed to make a cam “ big”.
[Re: TRENDZ]
#2669241
06/24/19 07:16 AM
06/24/19 07:16 AM
RapidRobert
Alright I will ask Dwayne what he recommends for specs & I will call those guys. Thank you
[Re: lewtot184]
#2669244
06/24/19 07:36 AM
06/24/19 07:36 AM
RapidRobert
I dont remember what I paid for the cam but even if it ends up being a bit more (after a regrind) than what another one would cost I would feel better than haveing another part on the shelf that will never be put to use. I'll get some desired specs first.
[Re: RapidRobert]
#2669247
06/24/19 07:55 AM
06/24/19 07:55 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Is this a solid flat tappet? I’m just thinking out loud here, but seems like with the cost to regrind and the shipping back and forth, you might be ahead by just ordering up a new cam with the specs you want.
2 kids and a dog
[Re: TonyS451]
#2669248
06/24/19 08:00 AM
06/24/19 08:00 AM
RapidRobert
Yes it is a solid flat tappet. Agreed, there would be a ($$$) point where it would make sense to get a new one.
[Re: RapidRobert]
#2669271
06/24/19 09:12 AM
06/24/19 09:12 AM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
I'd say, probably easier to sell it and get what you need instead.
Rich H.
Esse Quam Videri
[Re: TonyS451]
#2669295
06/24/19 10:14 AM
06/24/19 10:14 AM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is this a solid flat tappet? I’m just thinking out loud here, but seems like with the cost to regrind and the shipping back and forth, you might be ahead by just ordering up a new cam with the specs you want. Ding ding ding!!!! I'd say, probably easier to sell it and get what you need instead. Ding ding ding!!!!
[Re: fast68plymouth]
#2669305
06/24/19 10:49 AM
06/24/19 10:49 AM
RapidRobert
I do believe we have a winna. Dwayne you are the man on this stuff so I will take your advise
