Re: W-2 Heads & W-2 Victor Intake
[Re: dizuster]
#2669371
06/24/19 01:42 PM
06/24/19 01:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Look at the push rod area and see if the push rod area has been opened up.. usually (at least on my 3 sets of W-2s)if they have been opened up the that area will show it if it has 3/8"PRs.. if not they are most likely angle cut.. one of my sets was cut to just have it match up to my intake(W-2 intake)
[Re: topside]
#2669387
06/24/19 02:14 PM
06/24/19 02:14 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Glidden was the point man for the W2 stuff; Hamburger was primarily working Stock & SS, though there was 1 Duster (the Hamburger & Sweitzer car) that ran outside of that realm in B/SM. I've tracked down all of the early Dusters except that one (distinguished by large (long) wheel openings) and one of the '74s, which was white and usually referred to as the Hall Of Fame car. The rest were blue & white in that diagonal scheme. I'm really curious about the car in FL ! Long before Glidden made the switch to Mopar both Hamburger and John Deianna where involved in developing the W2 heads from original T/A castings, a friend of mine ended up with the best set Deianna had after he quit drag racing. He told us when we picked up all the parts he sold us that Mopar would have him air freight the heads back to them in Detroit after every race and work on them some more, he figure they had spent nearly $10,000.00 on air freight in shipping alone BTW they where converted to oval ports, not square ports like those T/A heads where originally
[Re: 500ciDuster]
#2669924
06/25/19 08:27 PM
06/25/19 08:27 PM
Posts: 1,798 McGregor,Iowa 52157
500ciDuster
McGregor,Iowa 52157
Push rod clearances looks factory but may have been opened up, has aluminum MT rods that look to be 6" long, could read on the bottom of the pistons H400 040 which makes me wonder if those were chiivie pistons? Were full domes with nothing milled off, has a huge roller cam that I'm going to measure eventually, big aluminum oil pan w/solid windage tray and scraper, crank is solid w/out holes drilled threw the end throws and has small radius on the rod journals, has offset dowels for fine tuning the heads which Ed used to sell, My friend was told that it had been on a dyno and was around 600, would that be a stretch?
