Re: Oil pump
[Re: jkwedge540]
#2668146
06/20/19 09:50 PM
06/20/19 09:50 PM
RapidRobert
I would do some basic oil passage mods & start with a std vol pump & see what you get for pressure. Not sure of a preferred brand, oil pumps are very trouble free as a rule. Just check several clearances/relief valve moves free.
Re: Oil pump
[Re: RapidRobert]
#2668150
06/20/19 09:56 PM
06/20/19 09:56 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I agree. Your engine is fresh. Bearings are tight. (Not wore out.) Stock Melling pump will probably work fine. If not you can put the Melling high volume on. Now-a-days the trend is to get away from the huge oil pumps and high pressure of the past.
2011 Drag Pak Challenger
Re: Oil pump
[Re: jkwedge540]
#2668240
06/21/19 07:44 AM
06/21/19 07:44 AM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
It's usually pretty hard to go wrong with an M63HV.
A little prep work goes a long way. The old tech archives (not the one with every post someone felt like saving....the other older one) has some good info on that.
Rich H.
Esse Quam Videri
Re: Oil pump
[Re: ZIPPY]
#2668286
06/21/19 10:37 AM
06/21/19 10:37 AM
Posts: 4,688 On the parachute mount
n20mstr
ITS WHAT I USE ! HAD THE SAME ONE ON DIFFERENT MOTORS FOR 20+ YEARS NOW !
....BAD A$$ STREET CAR.....
Re: Oil pump
[Re: n20mstr]
#2668340
06/21/19 12:27 PM
06/21/19 12:27 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Bearing clearance is the determining factor, if your clearances are on the tight side, all a HV pump is gonna do is raise the pressure and cause parasitic loss.
Re: Oil pump
[Re: jkwedge540]
#2668350
06/21/19 12:54 PM
06/21/19 12:54 PM
Posts: 31,050 Oregon
AndyF
Getting ready to build a 500 inch 440. Whitch oil pump do yo guys recommend. Going to spin it no more then 6200.street car mostly. The standard volume oil pump is all you need for a low RPM engine with normal bearing clearances. You might want to shim the spring to build a little more pressure but that depends on bearing clearances and oil viscosity. Sometimes you just have to try it to see what the engine needs.
Re: Oil pump
[Re: AndyF]
#2668397
06/21/19 03:07 PM
06/21/19 03:07 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Getting ready to build a 500 inch 440. Whitch oil pump do yo guys recommend. Going to spin it no more then 6200.street car mostly. The standard volume oil pump is all you need for a low RPM engine with normal bearing clearances. You might want to shim the spring to build a little more pressure but that depends on bearing clearances and oil viscosity. Sometimes you just have to try it to see what the engine needs. I the OP's situation a HV will just be blowing oil through the bypass and wasting energy. You can spend money in a lot better places than a fancy oil pump on this type of build.
Re: Oil pump
[Re: jkwedge540]
#2668632
06/22/19 09:26 AM
06/22/19 09:26 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
So a standard Mellings pump is good? I too would suggest standard volume pump. But I do get the high pressure. But that would probably be unnecessary as well for a lower rpm build at your power level. Always worthwhile to open them up, make sure the two halves align properly, and clean up the hard edges.
Re: Oil pump
[Re: BSB67]
#2668659
06/22/19 10:42 AM
06/22/19 10:42 AM
RapidRobert
do as many block oil mods as you feel comfortable with/blueprint the pump/alot of passage deburring (it is needed). that way your foundation is solid & the correct selection of add ons will give you what you want with the solid foundation in place (oiling/cooling etc). You might peruse Sanborns oiling/cooling mods that are in a sticky at www.moparchat then scroll down to & click on "circle track chat". SB stuff but alot is relevent for a BB. (long read but worth it).
Re: Oil pump
[Re: moparx]
#2669021
06/23/19 12:50 PM
06/23/19 12:50 PM
RapidRobert
agreed, I gotta get my printer fixed!
