'74 brougham 440, steel or cast crank? #2667964
06/20/19 11:39 AM
06/20/19 11:39 AM
RapidRobert Offline OP
which is likely? it is aways away. Thank you for your time.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2667982
06/20/19 12:19 PM
06/20/19 12:19 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My guess would be cast. I think mid 1973 or so cars switched to cast cranks. I've read some still got a forged crank if it had a 4 speed or was a truck or police engine. Others will more knowledge will chim in I'm sure.
Re: '74 brougham 440, steel or cast crank? [Re: DusterKid] #2668002
06/20/19 12:36 PM
06/20/19 12:36 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Can you get a photo of the balancer (harmonic damper)?
Likely a cast crank with the big lumpy balancer.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2668020
06/20/19 01:41 PM
06/20/19 01:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Standard performance likely cast, HP could go either way.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
Re: '74 brougham 440, steel or cast crank? [Re: John_Kunkel] #2668490
06/21/19 06:24 PM
06/21/19 06:24 PM
it is std so it sounds like the odds are that it is cast. If I get serious about I will have him eyeball it or take a pic. Thanks guys.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2668496
06/21/19 06:53 PM
06/21/19 06:53 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
If you arent planning on hooking it to a 4spd and won't be turning mega HP numbers, a well seasoned cast crank can take plenty of abuse.
Re: '74 brougham 440, steel or cast crank? [Re: Montclaire] #2668569
06/21/19 10:40 PM
06/21/19 10:40 PM
It's a pretty good shape original that I would keep as a daily driver . I'd be a little more generous if it would be a steel crank.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2668689
06/22/19 11:20 AM
06/22/19 11:20 AM
Central Florida
larrymopar360 Offline
Central Florida
Weren't steel cranks gone after 1972 in the 440, HP or not?
Facts are stubborn things.
Re: '74 brougham 440, steel or cast crank? [Re: larrymopar360] #2668696
06/22/19 11:41 AM
06/22/19 11:41 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I've seen 73 but maybe it was early and then I have a 74 motor home engine that has a steel
Re: '74 brougham 440, steel or cast crank? [Re: 500ciDuster] #2668708
06/22/19 12:10 PM
06/22/19 12:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Mopar SB
Re: '74 brougham 440, steel or cast crank? [Re: John_Kunkel] #2668783
06/22/19 05:20 PM
06/22/19 05:20 PM
Central Florida
Central Florida
I guess I should have written gone after '73, not '72, either way he's asking about '74.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2668800
06/22/19 06:23 PM
06/22/19 06:23 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
It honestly makes zero difference for what you want it for. It's lasted 45 years, I think you'll be good. shruggy
Re: '74 brougham 440, steel or cast crank? [Re: Montclaire] #2668815
06/22/19 07:23 PM
06/22/19 07:23 PM
Yes for a DD it makes no difference but if it is a steel crank it may (eventually) find a new home.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2669002
06/23/19 10:36 AM
06/23/19 10:36 AM
Central Florida
Central Florida
And, if you're like me, it feels really nice knowing you have a steel crank. I love overkill.
Re: '74 brougham 440, steel or cast crank? [Re: larrymopar360] #2669017
06/23/19 11:16 AM
06/23/19 11:16 AM
^^^ That's the story of my life brother. & if it is a steel cranker it will make we wanna grab/purchase another early A body to drop it into, Like I need another (un)finished project at the moment.
Re: '74 brougham 440, steel or cast crank? [Re: RapidRobert] #2669060
06/23/19 02:36 PM
06/23/19 02:36 PM
Central Florida
Central Florida
Cheap Nash
by RoadRunnerLuva. 01/27/20 03:40 PM
Hemi 4 speed 68 Charger
by Hemi_Joel. 01/27/20 02:40 PM
comp pro magnum rockers advice
by Since1822. 01/27/20 12:53 PM
welding/redrilling rear axle flanges
by HemiRick. 01/27/20 12:29 PM
Moparts Recent Posts
by Neil. 01/27/20 03:48 PM
Waited 30 Years ...
by HotRodDave. 01/27/20 03:41 PM
Cheap Nash
2011 4x4 problem
by HotRodDave. 01/27/20 03:39 PM
