The sad, sad state of classic car tuneup parts #2667632
06/19/19 03:47 PM
06/19/19 03:47 PM
Connecticut
CrAlt Offline OP
CrAlt  Offline OP
Connecticut
I was having issues keeping points alive in a brand X car and happened upon this site: http://nonlintec.com/sprite/cap_failure/
Sure enough.. every new condenser I had gotten where all junk. Basically fake. Even even name brands you used to be able to trust.
Before that I was drivability problems with another brand X car that uses the bread and butter GM HEI system. Turns out new replacement 4pin modules no longer seem to support expanding dwell with RPM. Ya you can get module for 9 bux now but they are not much better then points.
Then I was reading about the slantsix guys having problems finding usable distributor caps/rotors: http://www.slantsix.org/forum/viewtopic.php?f=19&t=60552
And now I bring you todays chrysler ICM. This box is sold under a few different brands anywhere from 13bux to 50.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: The sad, sad state of classic car tuneup parts [Re: CrAlt] #2667633
06/19/19 03:51 PM
06/19/19 03:51 PM
Connecticut
CrAlt Offline OP
CrAlt  Offline OP
Connecticut
Yep the transistor is fake. cry
The little power transistor looks like "ST 981Q Morocco bu911t"
Not sure how long it would have lived barely being pressed up against the tin case for a heatsink even if it wasn't undersized.
Re: The sad, sad state of classic car tuneup parts [Re: CrAlt] #2667639
06/19/19 04:12 PM
06/19/19 04:12 PM
P
Porter67 Offline
Porter67  Offline
P
And of course its the great guys in the mopar world bringing this junk to us.
Add a 1/10 of a cent sticker and charge $10 more.
I use this on my test run stand, cant say id use it on a car.
Re: The sad, sad state of classic car tuneup parts [Re: Porter67] #2667641
06/19/19 04:15 PM
06/19/19 04:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That is why I usually look for NOS parts if the cost is not ridiculous.
Re: The sad, sad state of classic car tuneup parts [Re: CrAlt] #2667644
06/19/19 04:38 PM
06/19/19 04:38 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Its not just 'classic' cars anymore. Get up into the 15-30 year old range now and things are going down the drain quickly. More and more white box off shore garbage is becoming the only option besides used which anymore I have taken a less apprehensive approach to doing.
It has been said before I'm sure and I will say I do often now. Rockauto can be a gold mine for new old retail stock (NORS) on closeout. Last month I bought 20 NORS ball joints for less than $4/each, at one point they were $35+ each but discontinued by the mfg who also got gobbled up by a competitor... NORS drum brake hardware kits for $2.50/each and all good USA made stuff. On and on it goes. The stuff is out there if you dont mind storing it for use later on.
Re: The sad, sad state of classic car tuneup parts [Re: 135sohc] #2667652
06/19/19 04:58 PM
06/19/19 04:58 PM
P
Porter67 Offline
Porter67  Offline
P
How do you figure these rate?
I bought two of these Standard LX101 units for a decent price. I really dont want to rip one open to see.
Re: The sad, sad state of classic car tuneup parts [Re: Porter67] #2667657
06/19/19 05:19 PM
06/19/19 05:19 PM
Connecticut
CrAlt Offline OP
CrAlt  Offline OP
Connecticut
I dont know the ins and outs of the mopar icm but if you hook it up and stick a volt meter between the metal case and the ground of the unit there should be some voltage. Maybe something like 400 volts. I remember getting shocked from them before. I am going to go with REAL on your unit because if you look up the datasheet on the BU931 it's a "HIGH VOLTAGE IGNITION COIL DRIVER". Wouldn't make sense to spend the money on that part and then not use it.
I found thread talking about the ICM's but it's from 2014 and most of the pics are broken unfortunately.
http://www.dodgecharger.com/forum/index.php/topic,92253.0.html
Looking at photo's of old ones it seems most aftermarket ones used /\/\otorola or RCA made transistors.
Maybe someone who knows NOS or has a collection can share some more info.
Re: The sad, sad state of classic car tuneup parts [Re: Porter67] #2667799
06/20/19 12:06 AM
06/20/19 12:06 AM
North Central USA (MN-WI area)
MuscleMopars Offline
I bought one of these and I am running it on my car now with no issues. Is there something wrong with this product???
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI
612-669-CARS
Go to my Moparts "Profile" to see my web site
Re: The sad, sad state of classic car tuneup parts [Re: MuscleMopars] #2667822
06/20/19 05:10 AM
06/20/19 05:10 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
AND... did he advertise it fraudulently? Have you taken it up with him before posting this?
The new parts = cheap sh!t topic is an important one, its a troubling reality, and garbage parts and shysters should be called out, but this smells a bit personal...
Re: The sad, sad state of classic car tuneup parts [Re: Pale_Roader] #2667843
06/20/19 07:47 AM
06/20/19 07:47 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
im struggling with voltage regulator with my cummins. Finally pulled a spare for my wagon out and its been good.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: The sad, sad state of classic car tuneup parts [Re: 135sohc] #2667850
06/20/19 08:02 AM
06/20/19 08:02 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
iagree A lot of aftermarket parts are junk, especially what you get from the chain auto parts places.
A lot of shadetree guys just want the cheapest part they can get, and the market has obliged...
Re: The sad, sad state of classic car tuneup parts [Re: wingman] #2667880
06/20/19 09:41 AM
06/20/19 09:41 AM
P
Porter67 Offline
Porter67  Offline
P
Some of you flakes read too much into things, I was going to post Jegs also sells the same box but didnt see it as important.
Alot of mopar vendors sell cheap china junk. Better? Dont care if ya think so or not.
Either way whoever sells it, cant expect much for $31
https://www.ebay.com/itm/JEGS-40805-HiRev-7500-0174-Ignition-Control-Unit/401694902755?
Re: The sad, sad state of classic car tuneup parts [Re: MuscleMopars] #2667882
06/20/19 09:45 AM
06/20/19 09:45 AM
Perkiomenville PA
RWG75 Offline
RWG75  Offline
Perkiomenville PA
Yeah - they have a life span of about a year. Was rehabbing a tin grille truck, bought one "just because" while doing cap / rotor / plugs / wires. A year of so later I ended up putting the 40 yr old original back in because the look alike went poof. Your mileage may vary but built like cheap crap is gonna perform like cheap crap.
BTW, not a recent development - the aftermarket has been building them with fake transistors for close to a decade. Clearly not 100% of them for that long but I think it'd be pretty hard to find a real deal aftermarket one today.
75 Charger SE - 440/4, cop suspension
76 Daytona - survivor
76 Daytona - tweaked
77 PW - macho clone, sno-commander, frankenram
79 RC - this was your fathers 4x4
79 LRE - More fun than it looks
Re: The sad, sad state of classic car tuneup parts [Re: RWG75] #2667895
06/20/19 10:13 AM
06/20/19 10:13 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Well, here is my take. To understand what the box is, is to understand that its just a switch. Basically the pick up in the distributor sends a signal when the metal point crosses the magnetic field. This "signal" is processed with some electronic to add in proper timing, dwell, etc. That large transistor is the high current switch to charge the coil based on the low current signal from the pickup.
The new boxes probably make use of more efficient electronic components so it is possible to have a more efficient design. However, I'd still be comfortable with the larger transistor and heat sink for reliability. I think if it were me, and the new boxes are just shells, id go with MDS or Pertronix or others. If originality is a concern, then I am not sure what I would do.
68 Road Runner (383/4speed, post car w/decor pkg)
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
Re: The sad, sad state of classic car tuneup parts [Re: RWG75] #2667897
06/20/19 10:17 AM
06/20/19 10:17 AM
Connecticut
CrAlt Offline OP
CrAlt  Offline OP
Connecticut
I suspect if they spent the few cents properly heat sinking the little TO-220 transistor inside rather then on the big fake TO3 transistor and heat sink on the outside the box might actually work a long time.
The BU911 I found inside maybe underspec'ed to begin with* but not correctly heat sinking it is just condemning it to death. frown
I found a photo of a different aftermarket ICM. If that rivet in the case is holding the internal TO-220 to the case for heatsink then I see that as an honest design at least.
(*compared to PN#'s in the photo's of real external TO3 transistors I can find)
Re: The sad, sad state of classic car tuneup parts [Re: CrAlt] #2667898
06/20/19 10:19 AM
06/20/19 10:19 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We source products from China on a regular basis, and have found the Mopar box available for <$4 in quantities of 250 pieces..
Just my $0.02... wink
Re: The sad, sad state of classic car tuneup parts [Re: mopars4ever] #2668093
06/20/19 06:45 PM
06/20/19 06:45 PM
Between Houston & Galveston TX
Satilite73 Offline
Satilite73  Offline
Isn't this about the time MP's orange box went to crap too? I had an orange box from '91 that lasted hundreds of thousands of miles having been installed on several cars before it went bad. Bought a new replacement about 2006 or so, it didn't last a year. I still have the box from '91. It'll start and idle a car, but extended use.........things get interesting. hop
John
Imagine a '73 Satellite Wagon picture here. 😁
Re: The sad, sad state of classic car tuneup parts [Re: Satilite73] #2668177
06/20/19 11:01 PM
06/20/19 11:01 PM
Walmart parking lot
yorker Offline
Drugs are bad
yorker  Offline
Drugs are bad
Walmart parking lot
About 5 years ago, I had a 1988 Town Car and it needed a new starter relay, the thing mounted on the inside fender. Problem was I started it onetime, released the key and the starter stayed engaged, and could not shut off engine. I was lucky the battery cable was not tight and killed it that way. This was a low mileage and clean car.I went to NAPA and bought a relay. It was good for about 6 starts. Then the same problem.I took it back and put on another relay, same issue. I then checked the starter switch in the colum, looked good, I replaced it anyway. I then replaced the relay again, I think. same problem. So I put on a rebuilt starter, still having problems.
I then took off the 3 rd. NAPA relay and got one fromAuto Zone. Never had a problem after that.
Guess Napa relays were made with thinner copper wires or something.
t That lincoln was a very good riding car, rode better than the 97 Town Car I had.
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: The sad, sad state of classic car tuneup parts [Re: Satilite73] #2668215
06/21/19 03:37 AM
06/21/19 03:37 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I had six in a row go bad. Took them all to a swap meet, put a sign on them that said 'six for $5, none work, but the orange paint is pretty'. It was a joke. Until some guy came along and happily gave me $5. I said 'you know those dont work right?' He said yup! Off he went...
Its pretty bad when your box ov emergency electrical parts you keep in the trunk is full ov 40 year old pull-off parts from running cars because you dont trust parts counter parts anymore...
Re: The sad, sad state of classic car tuneup parts [Re: Pale_Roader] #2668292
06/21/19 10:47 AM
06/21/19 10:47 AM
Perkiomenville PA
RWG75 Offline
RWG75  Offline
Perkiomenville PA
I thought I was the only one that did that!
A couple ECUs, a couple ballast resistors, a couple regulators, a rotor, a coil, some scotch brite and enough tools to swap all of it in a small little box tucked inside the spare tire.
1974 dodge dart - $800
by FM3_1970. 06/05/20 01:06 PM
1969 gTx - brown
by Not yr uncle Bob. 06/05/20 12:30 PM
Well....... that seemed worth doing
by fast68plymouth. 06/05/20 12:25 PM
Front height adjustment
by robertop. 06/05/20 12:08 PM
Moparts Recent Posts
by T2R9. 06/05/20 02:05 PM
Tach acting erratic. 69 dodge
by parksr5. 06/05/20 02:02 PM
new SFT for the 511
by 440Jim. 06/05/20 02:02 PM
Chevelle board? A question on the 396/402
by 6bblgt. 06/05/20 02:02 PM
