michelin tires #2667447
06/19/19 07:00 AM
06/19/19 07:00 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I called michelin about tire for my 1999 3500 they told me to use AGILIS CROSSCLIMATE I ask them about the. XPS RIB and they said that would be ok also any body got experience with either one of them. Trying to get a straight answer from tire dealers and the mana factory should not be this hard. They act like they do not really know. Thanks
Re: michelin tires [Re: dragon] #2667485
06/19/19 09:41 AM
06/19/19 09:41 AM
Fort Worth, Texas
3hundred Offline
3hundred  Offline
Fort Worth, Texas
XPS Rib is an all steel tire, great if you're running at or over max weights. XPS Rib and Defender tires are highway / all season tires. Downside to Rib is the ride is noticeably rougher than a standard steel / fabric construction tire. I've never heard of the AGILIS CROSSCLIMATE, but it sounds like it's more of an aggressive tread for off road or slick conditions?
Robert
'68 Fury Convertible
'69 300 Convertible
'93 Ramcharger 5.7 Hemi
'93 Ramcharger 318 sold
'01 3500 4x4 Cummins 6 speed
'13 300 S sold
'15 Durango 5.7 Hemi
'16 300 S Hemi
pre 65 D100 window regulators...
by thehemikid. 10/21/19 12:26 AM
01 2500.... still making payments
by J_BODY. 10/20/19 11:35 PM
last spirited ride in the Barracuda
by mopar dave. 10/20/19 10:59 PM
Finally got everything working together...
by GY3. 10/20/19 10:56 PM
Moparts Recent Posts
Do you use offset lifters with you 440 -1 heads?
by Jeremiah. 10/21/19 12:22 AM
Safely Wiring Accessories/Amp Gauge Re-wire
by Jim_Lusk. 10/21/19 12:21 AM
by tex013. 10/21/19 12:13 AM
