Gravely zero turn mower #2667142
06/18/19 10:34 AM
06/18/19 10:34 AM
Cleveland Ohio
sportfury70 Offline OP
Cleveland Ohio
I have a brand new Gravely proturn 460 that doesnot seem to be cutting very well. The 1st time I used it it was leaving dandelions completely uncut. The next time I noticed it was leaving grass uncut. Both times the uncut grass seems to be exactly on the middle of the deck.
I took it to the dealer & they tried it (with me there) & it cut very nicely. He lowered the deck to 1.75" & it cut very nicely. I had it set @ 3.25-3.5"
Anybody have experience with these mowers that can offer a suggestion to improve cut quality? Thanks.
Lewis
Re: Gravely zero turn mower [Re: sportfury70] #2667188
06/18/19 01:13 PM
06/18/19 01:13 PM
Kingston, IL USA!
gts340swinger Offline
Kingston, IL USA!
Did you try sharpening the blades? For some reason, new blades aren't really too sharp. Dandelions are tough to cut anyway but I'd think a brand new zero turn, with the engine running at the proper speed, should have no trouble cutting. I can't imagine anything else being the problem, although it's frustrating. I have a brand new Hustler Raptor Limited and it cuts beautifully.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
69 D100 (Ed)
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
99 Dakota R/T
77 Volare wagon.
Re: Gravely zero turn mower [Re: gts340swinger] #2667189
06/18/19 01:16 PM
06/18/19 01:16 PM
New York
VCODE Offline
VCODE  Offline
New York
I have a Toro zero turn, cuts very nice. What I don't like about it is the control levers are too sensitive.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17 (Robert what is a 440 Six-Pack)
Re: Gravely zero turn mower [Re: VCODE] #2667208
06/18/19 01:55 PM
06/18/19 01:55 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Sharpen your blades. That's the easiest and most obvious solution. If that doesn't fix it then let us know...
Re: Gravely zero turn mower [Re: sportfury70] #2667214
06/18/19 02:09 PM
06/18/19 02:09 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Maybe the dealer assembler installed the mower blades UPSIDE DOWN? Don't know if that is possible on all blades but all mower blades are supposed to "suck" the grass up to the blades. Also there are different pitch mower blades that pull more or less vacuum and on some mowers the manufactures have a limit to how much pitch is allowed for their mowers. Maybe your mower has the wrong pitch blades and sharp or not they won't "pull" the grass up to cut correctly?????
Re: Gravely zero turn mower [Re: sportfury70] #2667220
06/18/19 02:19 PM
06/18/19 02:19 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
My Fastrack mows much better with the deck in a lower position. It seems like it's blowing the grass over, preventing a clean cut with the higher settings.
Re: Gravely zero turn mower [Re: 74RALLYE] #2667241
06/18/19 03:06 PM
06/18/19 03:06 PM
Cleveland Ohio
Cleveland Ohio
The person at the dealer looked at the blades because he thought they would be dull. He said they are very sharp. I've only used the mower 3 times and this last time it was very tall. I will try mowing lower. Maybe about 2.5" and see if it mows nicer. Thanks
Re: Gravely zero turn mower [Re: sportfury70] #2667273
06/18/19 04:13 PM
06/18/19 04:13 PM
The frozen wasteland of Iowa
tboomer Offline
tboomer  Offline
How's the tire pressure?
A country boy can survive (Hank Williams)
Re: Gravely zero turn mower [Re: tboomer] #2667291
06/18/19 05:06 PM
06/18/19 05:06 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Try going faster. I'm betting the grass blades are ducking the new mower since it sounds different. Might have to go faster just so they can't duck
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Gravely zero turn mower [Re: A12] #2667305
06/18/19 06:06 PM
06/18/19 06:06 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep mower blades and mower decks SUCK......If you don't get it to mow like you want put mower blades on that SUCK more and stand (SUCK) the grass up higher
Re: Gravely zero turn mower [Re: A12] #2667325
06/18/19 06:51 PM
06/18/19 06:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
How did the dealer set the mower blade pitch..........I never heard of this but maybe it's a consideration for your Gravely?
https://www.lawnmowerforum.com/showthread.php/14450-Blade-Pitch-Professionals-Use
Re: Gravely zero turn mower [Re: sportfury70] #2667352
06/18/19 08:09 PM
06/18/19 08:09 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I wonder if high lift style blades are available for your mower ? I ran into a similar problem on my old ancient MTD special that I refuse to replace, one blade change I unknowingly got the 'standard' blades and unless the deck was slammed to the ground for the golf course buzz cut it would not cut evenly and could not operate the bagger. Back to the high lift blades and all was good again.
Re: Gravely zero turn mower [Re: sportfury70] #2667399
06/18/19 10:16 PM
06/18/19 10:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Set the cut height to 2 1\2- 3/4" and it 'll mow great. I have a Gravly 260z and it doesn't cut well at 3- 3 1/2" .
BTW, you are running it wide open, the throttle that is.
Re: Gravely zero turn mower [Re: justinp61] #2667443
06/19/19 06:26 AM
06/19/19 06:26 AM
Cleveland Ohio
Cleveland Ohio
Yes, I run at full throttle. I will try cutting st 2.75" thank you
Re: Gravely zero turn mower [Re: sportfury70] #2667444
06/19/19 06:32 AM
06/19/19 06:32 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
How tall is the grass/weeds? How damp is it? Tall grass/tall weeds will be laid over by the leading edge of the mower deck and will not be pulled up, or spring back up to be cut by the blade particularly where the blade is close the the deck's leading edge.
Re: Gravely zero turn mower [Re: sportfury70] #2667467
06/19/19 08:55 AM
06/19/19 08:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Gravely zero turn mower [Re: justinp61] #2667602
06/19/19 02:02 PM
06/19/19 02:02 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The question here is how do you know how good a new mower is going to cut the grass? That is a real expensive lawn mower not to be cutting the way you want it! I like to cut my grass tall. You should not have that problem with a good mower! They just don’t make lawn mowers as good as they used to. In fact, I heard that MTD makes the basic decks for most of the makes like Cub Cadet, John Deere, Yard Man, Troy-Bilt, etc. ... at least for the lower priced models. Not necessarily for a zero-turn, but a 46” deck is basically the same one that you see on many lawn mowers with different names that you find for sale at Walmarts, Home Depot and Lowe’s. I’m guilty of going for a cheap lawn mower (Troy-Bilt bought at Lowe’s) and regret it every time I cut the grass. After reading this thread, I’m going to look into different blades to hopefully lift the grass up more. I would hate to spend a lot of money on a new mower and still not be happy with the results.
Re: Gravely zero turn mower [Re: RoadRunnerJD] #2667733
06/19/19 08:38 PM
06/19/19 08:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Of course we really don't know the specifics of exactly what's happening with the OP's mower. But what I stated above happens on several mowers that I've used, even my current zero turn. Even with that, I could not be more pleased with the it. I think it is a matter of expectations. If the mower deck is holding down the bend over grass is it reasonable to expect it to all be cut cleanly the first pass? If I cut a lawn +8" tall and depending on the grass and conditions some of the grass wont get cut for the reason I stated, Second pass in the opposite direction gets the rest of it. The blades are pretty robust and the high lift version broadcasts the cuttings about 12 ft out the chute. Suction and lift are not the issue with mine, IMO.
Re: Gravely zero turn mower [Re: BSB67] #2667755
06/19/19 09:44 PM
06/19/19 09:44 PM
Freeport IL USA
P
poorboy Offline
poorboy  Offline
P
Freeport IL USA
On my zero-turn mower, the blade speed and the travel speed are not related. The blades spin at the preset speed with the throttle wide open, but I can make the mower move faster then it will cut the grass, especially if the grass is longer. I usually can not run the mower as fast as it will travel if I want all the grass cut the 1st time.
Is the OP trying to travel too fast?
My zero-turn mows pretty nicely set at 4" high, after I finally got the anti scalping wheels set at the proper height. Gene
Re: Gravely zero turn mower [Re: poorboy] #2668223
06/21/19 06:44 AM
06/21/19 06:44 AM
Cleveland Ohio
Cleveland Ohio
Thanks for the feedback guys! I'm not sure how the deck is pitched. I asked the dealer what adjustments I will need to make and he said none. I did a Google search as well and came up with quite a bit of info so I must not be the only one. The good news is that with adjustments of the deck pitch and baffles I should be able to fix this issue.
I'll update later. Thanks again. Lewis
Carburetor mounting
by 340cpe. 06/02/20 10:07 PM
'69 Charger starting problem
by moparfan53. 06/02/20 09:32 PM
internal alternator parts worth anything?
by Mr T2U. 06/02/20 09:03 PM
Age of Slicks
by 6_pack_runner. 06/02/20 08:35 PM
Moparts Recent Posts
Mystery in oil pan???
by 4406bbl. 06/03/20 12:04 AM
Cool video made; no Mopars in it
by FM3AAR. 06/03/20 12:03 AM
PPP shifter?
by 493_john. 06/02/20 11:32 PM
How many miles do you drive?
by stumpy. 06/02/20 11:20 PM
