Re: Fasteners / Clips for 67 Coronet Convertible
[Re: calif67rt]
#2667032
06/17/19 09:57 PM
06/17/19 09:57 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
I thought I recall that the 67 b-body convertible used the same clips as the a-body. If so R/T had them as of last summer. I waited over 2 years for my set. Layson should have as well since they use the same source.
[Re: SportF]
#2667389
06/18/19 09:45 PM
06/18/19 09:45 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Go down to NAPA and look at the trim clips they have there. And they can get more. It will be the best value you can find. ..and the nice thing is NAPA has a catalog/binder containing a physical sample of each fastener they sell, so you can see the *actual* piece of the hardware before you buy it.. Some other thoughts... Most of the fasteners may be hidden, but still.. - Are there any other local 66 or 67's you can look at? - Do you have any friends, connections, or a car club that might have a similar car in your area? - Track down any old salvage yards locally, see of they have any 66 - 67's kicking around. Best, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: calif67rt]
#2669634
06/25/19 12:43 AM
06/25/19 12:43 AM
Posts: 1,042 Slidell, La.
doctor_mopar
Slidell, La.
About 30 years ago I gave Tom ( R/T Specialties ) a couple of my old original 67 Barracuda convertible top surround belt molding clips for a sample , and he eventually got them manufactured . They are very unique . Tom means well , but is overwhelmed with all he has to do , and I think your best bet is to try again with him . No one is more knowledgeable with so many fasteners , and which ones you need !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
