any of you guys ever used these LCA's #2666325
06/15/19 09:16 PM
06/15/19 09:16 PM
Mobile Al
hemirdrnnr Offline OP
Mobile Al
Any of you guys ever use these LCA's " AQA1 PRECISION PRODUCTS 52308 Lower Control Arms For Mopar 62-72 B-Body"? I have a 67 Plymouth Belvedere.
https://www.ebay.com/p/QA1-52308-Lower-Control-Arm/1226896467?_trksid=p2047675.l2644 "Not sure if this will work"!
Re: any of you guys ever used these LCA's [Re: hemirdrnnr] #2666328
06/15/19 09:31 PM
06/15/19 09:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A link would go a long way towards a useful answer
Re: any of you guys ever used these LCA's [Re: Sniper] #2666375
06/16/19 04:46 AM
06/16/19 04:46 AM
Mobile Al
Mobile Al
Sorry thought I attached the link try it now. haha
Re: any of you guys ever used these LCA's [Re: hemirdrnnr] #2666389
06/16/19 08:09 AM
06/16/19 08:09 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Looks interesting, guess it uses the coil overs they make but the factory shock tower might not be strong enough to support the weight..I think you need to buy the whole set up
Re: any of you guys ever used these LCA's [Re: AARCONV] #2666516
06/16/19 02:28 PM
06/16/19 02:28 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Buddy of mine built a set pretty close to those and put them on his '68 Satellite. He has coilovers and did not brace the shock towers. B body is a lot tougher in that area than an A body.
IIRC, QA-1 is the old CAP stuff.
Re: any of you guys ever used these LCA's [Re: hemirdrnnr] #2666592
06/16/19 05:44 PM
06/16/19 05:44 PM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
I have those LCA's on my 64 Belvedere, the whole QA1 front end kit in fact. No issues.
Re: any of you guys ever used these LCA's [Re: AARCONV] #2666595
06/16/19 06:00 PM
06/16/19 06:00 PM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
These are for use with torsion bars.
Re: any of you guys ever used these LCA's [Re: 64Bel] #2666636
06/16/19 07:48 PM
06/16/19 07:48 PM
Mobile Al
Mobile Al
"I have those LCA's on my 64 Belvedere, the whole QA1 front end kit in fact. No issues"
Do you drive it on the street or the track?.
Re: any of you guys ever used these LCA's [Re: hemirdrnnr] #2666680
06/16/19 09:57 PM
06/16/19 09:57 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I have the QA1 LCA just like those on my '70 Challenger. They were very easy to install and I drive it on the street all the time. I purchased mine from Mancini's a couple of
years ago. No issues so far.
Re: any of you guys ever used these LCA's [Re: 1969RR] #2666697
06/16/19 10:49 PM
06/16/19 10:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Someone care to explain to me the advantage of these ?
Re: any of you guys ever used these LCA's [Re: gtx6970] #2666712
06/16/19 11:51 PM
06/16/19 11:51 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: any of you guys ever used these LCA's [Re: hemirdrnnr] #2666713
06/17/19 12:02 AM
06/17/19 12:02 AM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
Street, but will see some track time eventually.
Re: any of you guys ever used these LCA's [Re: 64Bel] #2666737
06/17/19 06:55 AM
06/17/19 06:55 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
From QAI's website
https://www.qa1.net/mopar-control-arms
Quote
Lower Control Arms
QA1 offers Mopar A, B and E-Body control arms with sway bar tabs. These lower control arms are a direct bolt-in on your factory k-member and are twice as strong as factory arms and don't add any weight. The set includes bushings, pivot arms and nuts for ease of installation. Made in the USA.
Sounds to me like you get pretty much nothing out of them versus just buying the $20 stiffening plates for the factory control arms. Maybe you're car will be faster due to the driver now having a lighter wallet.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: any of you guys ever used these LCA's [Re: gtx6970] #2666744
06/17/19 08:07 AM
06/17/19 08:07 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO, it pretty well proves how non essential the LCA gusset modification is, as the pictured arms "maybe/seems to be" up to the task required, but are substantially less robust then the OEM LCA's, even without the gusset modification. biggrin
