Page 2 of 3 1 2 3
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #2966206
09/21/21 11:36 PM
09/21/21 11:36 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Oh,good. Would you buy these heads again? Gathering parts for a not stock 426 incher right now myself. I need to decide on heads.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: crowbait] #2966340
09/22/21 01:28 PM
09/22/21 01:28 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yes, I would buy them again for another similar built 572...(if Edelbrock would actually make and ship any, which they don't seem to be doing).
They're a pretty good value for someone who wants pretty big numbers out of the box without changing anything.
I am not 100% sure I would want them for a smaller cubic inch street combination, though, and would probably ask one of my
favored Horsepower Gods/Gurus for their opinion before proceeding. As (I believe) Edelbrock's own marketing states....designed to be
used on 528ci or larger.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #2966533
09/22/21 11:59 PM
09/22/21 11:59 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
I completely agree with you on the value of these,for ready to go and not "stock" per dollar spent. i just cant bring myself to buy a stock type mp aluminum head when there are these and the indy sr's and hi po's out there. It would forever be in the back of my mind wondering how much power I left on the table.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: crowbait] #2966535
09/23/21 12:44 AM
09/23/21 12:44 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I have a pair of Edelbrock Gen 2 Hemi heads on order through Hughes Engines who is setting them up for me. Is it possible to have these push rod channels opened up a bit for more clearance? I'll put it on my list of questions to ask Hughes when / if Edelbrock finally starts up production again.
Thoughts on clearancing prior to assembly?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: crowbait] #2966564
09/23/21 08:09 AM
09/23/21 08:09 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
"i just cant bring myself to buy a stock type mp aluminum head"
I haven't personally had access to the Chrysler parts system since '13, and can no longer physically check it out myself,
but if I can believe what folks have said offhand it seems MP killed those part numbers off anyway, and that's probably no longer an option (unless you find
someone who already has them). So, one less thing to worry about I guess.
"Is it possible to have these push rod channels opened up a bit for more clearance?
Thoughts on clearancing prior to assembly?"
Sure, most anything is possible (Whether it is practical or not is yet to be determined).
It's a thin brass tube pressed in. You can potentially press or cut the tube out, machine the hole bigger, hope you don't get into water and so on, and
press something else larger in. You can CNC the holes into an oval shape, and then custom make 8 special oval shaped tubes to press in.
There are many possibilities. Just nothing that I would do.
The engine was not fully assembled in the pictures shown, it was one of many mockups. Multiple mockups and corrections were done.
With the Victor Jr, one thing a person is not going to do successfully is stick a carbide bit in there and cut away at the casting to create some more clearance.
Again, It's a brass tube.
Instead of the above, alternately, an exhaust rocker other than Indy also seems to take care of it.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #2966718
09/23/21 03:26 PM
09/23/21 03:26 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I just built mine using Vic jr’s. Barton told me to run his 1.5 rocker on the exhaust. No clearance issues what so ever. .700 lift roller.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: 68 HEMI GTS] #2966990
09/24/21 11:43 AM
09/24/21 11:43 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yeah, those were also recommended to me per discussion with local race engine builder/guru.
Before I purchased my heads I was fortunate enough to be given a guided tour of new and old TD/Barton rocker setups and an explanation of how they've evolved,
they are super nice, but out of my league financially as I needed to spend that few thousand bucks on Sheetmetal for the car
more.
Indy shaft roller are the only one I know of with the interference problem shown here, it's just a certain combination of parts to watch out for,
thread was intended for information.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #3221808
03/20/24 10:43 PM
03/20/24 10:43 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
more.
After a few more years, are you still satisfied with using the stock 426 non roller tip rocker arms with the Victor heads? I finally have my BMP 4.5 bore block, and have Victor Jr. heads on order... the current plan is a 10.5:1 572 for my fake 71 Cuda.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: Craig J] #3221850
03/21/24 09:08 AM
03/21/24 09:08 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I'm very satisfied, but the statement is pretty meaningless because all the engine has done is hold down the engine dolly while I restore the car I'm installing it into.
I've fired it up without installing it, seems to run well, but that's about it, it's mothballed until the car is ready which will be awhile.
Rich H.
Esse Quam Videri
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #3221863
03/21/24 10:35 AM
03/21/24 10:35 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have 7/16 D.T. X. 165 wall in my Hemi with Mopar (Edelbrock) heads with over .800 lift, street driven and strip with the RBRE rocker system with no issues shifting at 7600 thus far. The RBRE rocker system helps take out so much of the push rod angles and corrects most of the geometry.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: 6PKRTSE] #3221875
03/21/24 11:13 AM
03/21/24 11:13 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Those blue rockers look so much sexier than the natural finish they have now.
2011 Drag Pak Challenger
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: rickseeman] #3221885
03/21/24 11:57 AM
03/21/24 11:57 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Thanks, I like them. They accessorize and match my car nicely since it is B5 blue. Their first batches were blue, then I believe they went to red, then I am sure due to cost they decided to leave raw (and even charge more for them). Lol.
They are now over $1000.00 per set more than they were back when I bought mine.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: 6PKRTSE] #3221996
03/21/24 09:20 PM
03/21/24 09:20 PM
Craig J Offline
Craig J  Offline
Do they fit under somewhat stock appearing valve covers? To anyone with even minimal hemi knowledge my car will never be anything other than a fake, but to a typical 5.0 mustang owner I want them to believe it is a stock 426 with a '3/4 race' cam. I am going to be using iron exhaust manifolds, mechanical fuel pump, clutch fan, etc...
Note: I feel it is fair for me to call a 3/4 inch cam a '3/4 race' cam
I am not ready for a 1 inch cam, commonly referred to as 'full race'
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: 6PKRTSE] #3222575
03/24/24 05:13 PM
03/24/24 05:13 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Do Stage V roller rockers on an Eddy Jr head have the same push rod clearance problems, I believe their ratios start ar 1.6 but not sure if there are 1.5s or 1.55. The TD are very nice and a friend has them on he 572 Hemi in his race car with the spray bars. I believe both oil via push rod and spray bar is available from T&D just the price is higher that many want to pay. Stock Type rocker from Mopar can be an experience testing to see how close they are in Ratio. Indy is a no for this type of set up. Those guys from Canada HemiGuys that sell both a Roller and Wide pad type of Hemi Rocker anyone used them on a good roller hemi set up with lots of spring pressure and did they survive. Looks like I am going to mock up and see if there is a contact problem in the Push Rod Guide. It was easier to run a 426 Cast iron motor then to go big 572 with Aluminum. Stage V heads out of FHO likely does not have this problem do to the size of the work Banning does on the push rod bushing. This is a good read and anyone used these parts BMBlock, Eddy Jr. Heads should make this a read before ordering or assembling.
1971 HEMI E BODY REGISTRY
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: hemicar1971] #3222589
03/24/24 07:30 PM
03/24/24 07:30 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've put several together with Victor Jrs and Stage V's. (Their standard 1.6) The engine on my test stand has that setup today. It is really, really close but I've never seen any witness marks on teardown.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: hemicar1971] #3222641
03/25/24 09:26 AM
03/25/24 09:26 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Where can somebody find this read? Thanks
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: ZIPPY] #3222645
03/25/24 09:43 AM
03/25/24 09:43 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
We used T&Ds setup for the Victor head. No spray oiling here. It's thru the cradle. Very nice. Used a factory ratio rocker arm on exhaust side. No clearance issues. Very quiet. I'd take it over the Barton setup tbh.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: Hot 340] #3222660
03/25/24 11:23 AM
03/25/24 11:23 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
T&D makes the Barton set up also.
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: 6PKRTSE] #3222675
03/25/24 12:41 PM
03/25/24 12:41 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Yes. They do. These are set up differently tho
Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info [Re: rickseeman] #3222691
03/25/24 01:27 PM
03/25/24 01:27 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
What I am saying is this thread is a good read. When Banning lived in Bewley, Ontario we would go there a lot. He would put those tubes in the Stage V Heads but were much bigger for a larger push rod.
So the problem seems to be on the Exhaust side of the push rod tube. Lowering the ratio seems to fix the problem with some rockers. I wanted to go the Stage V rockers way and might have to give Banning a call and see what he thinks and if Stage V has a 1.5 exhaust Rocker or something atleast under the 1.6. The final thing will be to mock up the motor and take alook at what clearance is there. The only problem with T&D is the price but you only want to do it once and not have to do it twice if something happens. If you go with a stock Factory type rocker then who would sell the most accurate ratio or is it just buy and hope things add up after checking. Quality control at it best.
Page 2 of 3 1 2 3
