Re: The one year challenge
[Re: JERICOGTX]
#2665027
06/12/19 08:34 AM
06/12/19 08:34 AM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
Yup, definetely a 20 footer... OK, so maybe a 19.5 footer. They should give you a medal for modesty. I received a medal for modesty once. But they took it away when I wore it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2665028
06/12/19 08:35 AM
06/12/19 08:35 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If that's a 20 footer, mine must be a one miler. Looks great!!!
[Re: jughed]
#2665047
06/12/19 09:17 AM
06/12/19 09:17 AM
Posts: 10,021 MN
JERICOGTX
MN
Gorgeous car!!!! Great build!! Is that EE1 blue?? Yes it is!
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2665169
06/12/19 02:33 PM
06/12/19 02:33 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Gorgeous car!!!! Great build!! Is that EE1 blue?? Yes it is! Great color choice. My '68 Dart will be that color.. if I can ever find a decent painter around here
[Re: jughed]
#2665718
06/14/19 07:16 AM
06/14/19 07:16 AM
Posts: 10,021 MN
JERICOGTX
MN
Some more buffing progress. Hoping to have it buffed in the next couple days, then start installing parts.
69 GTX
68 Road Runner
[Re: Hemi Allstate]
#2666777
06/17/19 10:00 AM
06/17/19 10:00 AM
Posts: 10,021 MN
JERICOGTX
MN
Was a very long but productive weekend. Car is buffed, and I started reassembling. Got a ways to go, but overall I'm happy with how it is turning out.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2666802
06/17/19 10:36 AM
06/17/19 10:36 AM
Posts: 625 Indianapolis In. usa
Quickrunner
20 footer my a$$, that thing is awesome! Great workmanship and skill!
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: Quickrunner]
#2666810
06/17/19 10:50 AM
06/17/19 10:50 AM
Posts: 10,021 MN
JERICOGTX
MN
20 footer my a$$, that thing is awesome! Great workmanship and skill! Thanks. It buffed out to a 15 footer.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2666849
06/17/19 11:40 AM
06/17/19 11:40 AM
Posts: 4,673 On the parachute mount
n20mstr
I SAW YOU USING SOME PPG PRODUCTS WHEN PAINTING THE INTERIOR PARTS, WHAT BASE COAT AND CLEAR ARE ON THE BODY?
REALLY NICE JOB SO FAR
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2666853
06/17/19 11:50 AM
06/17/19 11:50 AM
Posts: 10,021 MN
JERICOGTX
MN
REALLY NICE JOB SO FAR Used DBC for the base coat, and the local parts store EuroClear. Was hesitant on the clear at first, but I absolutely love the stuff. Sprays nice, lays out decent, wet sands nice, and buffs better than any clear I've ever used. I want to say the clear is made by Valspar, but not 100% sure.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2666867
06/17/19 12:24 PM
06/17/19 12:24 PM
n20mstr
REALLY NICE JOB SO FAR Used DBC for the base coat, and the local parts store EuroClear. Was hesitant on the clear at first, but I absolutely love the stuff. Sprays nice, lays out decent, wet sands nice, and buffs better than any clear I've ever used. I want to say the clear is made by Valspar, but not 100% sure. HOW MANY COATS ON THE CLEAR? BE CAREFUL THAT YOU ENDED UP WITH A GOOD MIL THICKNESS, SOME OF THE AFTERMARKET CLEARS REQUIRE THREE COATS OR MORE IF SANDING AND POLISHING. BUT IN YOUR CASE ITS GOING TO GET SANDED AND RECLEARED AGAIN DOWN THE ROAD, I THOUGHT I READ THAT A FEW PAGES BACK AGAIN NICE JOB, I CAN APPRECIATE IT BECAUSE I DO THIS STUFF MYSELF. YOUR TIME AND EFFORT REALLY SHOW. PICS NEVER DO THIS STUFF JUSTICE IM SURE ITS KILLER IN PERSON
[Re: n20mstr]
#2666872
06/17/19 12:39 PM
06/17/19 12:39 PM
Posts: 10,021 MN
JERICOGTX
MN
It has 4 coats of clear on it. First coat was pretty light and dry. Second and 3rd coat were medium coverage, and didn't look bad. $th was because I had enough mixed up, to cover it, and didn't want to just waste it, since I knew I'd be wet sanding and buffing anyways. I'll knock it all back down with 1000 grit, before having the lettering, and pin striping done.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2666893
06/17/19 01:18 PM
06/17/19 01:18 PM
n20mstr
It has 4 coats of clear on it. First coat was pretty light and dry. Second and 3rd coat were medium coverage, and didn't look bad. $th was because I had enough mixed up, to cover it, and didn't want to just waste it, since I knew I'd be wet sanding and buffing anyways. I'll knock it all back down with 1000 grit, before having the lettering, and pin striping done. SOUNDS GREAT ! LATELY I HAVE BEEN USING ALL NAME BRAND HIGH SOLIDS CLEARS, TWO COATS MAX AND IT ALWAYS LOOKS GREAT AT JUST TWO COATS. CUTS BACK ON THE LABOR TIME, AND MATERIALS...I ALWAYS DUMP IT BACK IN THE CUP BETWEEN COATS TO SEE HOW MUCH I SWHOULD BE MIXING....IF I HAVE TOO MUCH MIXED, I DUMP IT RATHER THAN PUT IT ON THE CAR. AGAIN, LOOKS GREAT, AND YOUR IDEA TO CLEAR AGAIN LATER IS GREAT, ANY SOAKAGE AT ALL YOULL DENFINITLEY GET RID OF IT THEN.
