Re: 46rh transmission troubles.
[Re: 383man]
#2665701
06/14/19 05:12 AM
06/14/19 05:12 AM
Posts: 9,827 MI, usa
dvw
MI, usa
I remember we had some problems with front drums when the trans did not want to go into third many times. I remember replacing the front drums with an updated one to correct this in some years but I forgot what years. Something to do with the finish on the drum causing the seal to stick some and not work right ? Ron I ran into this as well. Not the drum itself, but the finish on the high /rev apply piston inner surface. Never caused a 2/3 flare. trans just stayed in 2nd gear. Occasionally would shift 2/3 very late. Doug
[Re: dvw]
#2665730
06/14/19 08:27 AM
06/14/19 08:27 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I remember we had some problems with front drums when the trans did not want to go into third many times. I remember replacing the front drums with an updated one to correct this in some years but I forgot what years. Something to do with the finish on the drum causing the seal to stick some and not work right ? Ron I ran into this as well. Not the drum itself, but the finish on the high /rev apply piston inner surface. Never caused a 2/3 flare. trans just stayed in 2nd gear. Occasionally would shift 2/3 very late. Doug Your right Doug as I forgot we replaced the drum and piston. Ron
[Re: A727Tflite]
#2666181
06/15/19 12:46 PM
06/15/19 12:46 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
the gasket and seal kits nowadays also comes with a revised inner seal for the reverse high drum as some were machined too deep and the new seal has a wider cross section. reverse normally will work because of the pressure applied in reverse but third gear can be quite iffy as to whether or not it will apply. the revised inner seal will normally rectify the situation. How did it do during air checking while assembling?
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
