Re: 420 going on the dyno next couple days
[Re: biff426]
#2668576
06/21/19 11:55 PM
06/21/19 11:55 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Thanks for all the input guys all good stuff much appreciated. It just hit me. We talked about those behives on those heads before you even bought them, correct? Put a .010 pushrod in the motor
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: biff426]
#2668592
06/22/19 06:22 AM
06/22/19 06:22 AM
sixpackgut
Charleston
In current motor I have been running for years has been stock lifter. The other set for new engine and the lifter Steff was running is the hylift 2335s lifter
[Re: fbs63]
#2668666
06/22/19 11:01 AM
06/22/19 11:01 AM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Throw that sucker in this car.
[Re: pittsburghracer]
#2668794
06/22/19 06:48 PM
06/22/19 06:48 PM
sixpackgut
Charleston
Whos car is that? Always wanted one. They look great with big tire too
[Re: sixpackgut]
#2668796
06/22/19 07:02 PM
06/22/19 07:02 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Whos car is that? Always wanted one. They look great with big tire too Brad watt had a picture of it and a post looking for this car for a Friend. A for sale ad came up shortly after that. I think it’s in Ohio
#2668797
06/22/19 07:05 PM
06/22/19 07:05 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think an 8 second Gen 3 would look pretty cool planted between the frame rails
#2668798
06/22/19 07:16 PM
06/22/19 07:16 PM
sixpackgut
Charleston
I think an 8 second Gen 3 would look pretty cool planted between the frame rails If I had you money I would buy it
[Re: sixpackgut]
#2668801
06/22/19 07:27 PM
06/22/19 07:27 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think an 8 second Gen 3 would look pretty cool planted between the frame rails If I had you money I would buy it If I had your money I would build a Gen 3.
#2668839
06/22/19 09:49 PM
06/22/19 09:49 PM
sixpackgut
Charleston
I think an 8 second Gen 3 would look pretty cool planted between the frame rails If I had you money I would buy it If I had your money I would build a Gen 3. Lol touche
[Re: biff426]
#2671328
06/28/19 09:46 PM
06/28/19 09:46 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
SO made a couple hits with the 850 dyno carb and timing from 20-26 degrees it liked 22 made 748HP.@7300. Putting the bigger carb and spacers on it and going to play with jetting should be worth some HP. ALso the headers we had to use are 13/4 and the ones going in the car are 2" not sure what if anything that will do. Can't get the 2" to fit on the dyno without reinventing the wheel. I was within 8hp,,,,,,,,Nice little beast there.
[Re: biff426]
#2750934
03/11/20 09:49 AM
03/11/20 09:49 AM
Posts: 935 Deland, Florida
biff426
Deland, Florida
All the updates are done its back on the dyno hopefully we can make in the 775hp range updates Short travel lifters Manton Shafts Vac pump Spring change to PSI 1516 lash caps putting the 2 inch header on it We had some valve float issues on the last pulls we made before the updates
Re: 420 going on the dyno updated 3-11-20
[Re: biff426]
#2750994
03/11/20 01:03 PM
03/11/20 01:03 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
Am I reading this all right that you made 750ish HP with stock rockers and lifters?
